RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 06-17-2004, 01:00 AM   #1
jordandvm's Avatar
2017 28' International
Western , Oregon
Images: 58
Atwood water heater/fridge fan
Took my 22' CCD out overnight solo to paint with a local art group yesterday & today (was boondocking for the first time & looking for any excuse to take out the A/S)! Didn't quite know what to expect, but knew the battery was charged when I started. Anyway, I parked in a field, set up the normal way (took me 30 minutes to set up the ZipDee awning, but finally got it), then turned on the Water heater switch above the "Status switch". After a while I tried the hot water and noticed there was none. So, pulled out the manuals. It said that if the switch light was still on (red), you need to turn it off for 5-10 minutes, then hit it again. I did, and the light went off, and the heater was working. Is this a common problem? I've never had this happen before (previous 2 trips, with hookups).
Also, I brought it back to storage, dumped, and flushed the B/W tank twice....then backed into my bay. I turned off the fridge before return trip (but forgot to turn off the propane tank). Propane tanks turned off on return. I plugged in the power to an outlet to recharge the battery, then went back into the A/S to recheck all. I noticed the fridge fan was still running, but both switches to the fridge were off. This did not seem right, so unplugged the power cord and turned off the power switch inside the trailer and the fan went off, but could not recharge the battery this way. My question is.. should the fridge fan still be working if everything is turned off and am hooked up to recharge the battery?
You all have been very helpful in breaking in this newbie A/S owner!
Jim & Cheryl
2017 28' Signature CCD
2017 GMC Denali HD Crew Cab 4x4
Blue Ox Sway Pro Hitch
WBCCI #3538
jordandvm is offline   Reply With Quote
Old 06-17-2004, 05:36 AM   #2
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Jim,
The water heater issue is likely due to the fact that there was air in the LP lines and the heater relight cycle was not enough to purge them and light. After I have had my LP off, I aways start a burner on my stove before trying to start an auto ignition LP appliance.
This is a guess, as I have never seen the wiring, but the fridge fan was likely running due to the temp in the compartment. There may be a cut off switch in the compartment for the fan, other members have said they have one. Once the compartment is "cool" enough the fan would have turned off on it's own if it was working as designed.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 06-17-2004, 07:08 AM   #3
Tarheel's Avatar
2001 34' Limited S/O
Moyock , North Carolina
Images: 21
I've never paid that much attention to it, but it takes my unit sometimes as many as 5 tries to get the hot water heater to light. When the light comes on I just reset and hit it again. I don't want more than 5-10 sec. It hasn't blown up yet, and since there is no gas getting to the igniter I'm really not concerned that it will
Keep the shiny side up.
WBCCI # 348
Past Region 3 President
Past President Tidewater Unit 111
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
2004 international
Atwood water heater fast cycling Skater Water Heaters, Filters & Pumps 4 07-22-2011 08:02 PM
Atwood water heater burnt wire richinny Water Heaters, Filters & Pumps 5 06-21-2011 08:27 AM
Sealing around atwood water heater Hueytownalss Water Heaters, Filters & Pumps 1 06-02-2011 11:07 AM
Water Heater Calcium Deposits -- What to do? roscher Water Heaters, Filters & Pumps 7 05-18-2011 04:11 PM
atwood water being fitted to a 1960 Overlander Lothlorian Water Heaters, Filters & Pumps 10 01-01-2011 06:42 PM
