RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 01-18-2021, 09:45 PM   #1
1981 31' Excella II
High point , North Carolina
Help please...value of 1996 21’ sovereign!
Hi everyone,
I’m interested in purchasing this little beauty, but unfortunately I can’t find any similar units out there to help me with a value in its current condition. Seems like Airstream only produced the 21’ Sovereign from 1992-1996. I’m not sure if this makes this particular unit rare or not, but I haven’t had much luck finding any out there for sale. This unit is a one owner with working plumbing, working electrical, working refrigerator, and working A/C. Propane tanks and front couch are both missing. The current owner started removing the vinyl padded headliner because the adhesive backing had started to fail causing the headliner to droop in areas. Original flooring and cabinet doors have all been removed. Sub floor is super solid. No leaks and all windows work. The exterior shell has oxidation in some areas but overall in decent shape. There is one medium sized dent on the drivers side rear corner of the airstream. Underbelly is extremely clean. Tires, axles, and awning are in good working condition.
The Owner is firm at $14,000. I know it’s currently a sellers market but I want to make sure that I’m being fair to myself on the front side. Any help with the value of this unit in its current condition will be greatly appreciated. Thabks!
ID:	387192   Click image for larger version
ID:	387194   Click image for larger version
ID:	387196   Click image for larger version
ID:	387198   Click image for larger version
Duke336 is offline   Reply With Quote
Old 01-19-2021, 02:52 AM   #2
Iansk's Avatar
1977 31' Sovereign
Sunset Valley , Texas
A 21’ sovereign, huh... a few years observations if I may.
On the plus side, that looks to be a great layout for its size.
21’, while cozy, would be a breeze to tow and park.
As for unknowns ... the axles are at or approaching the end of there lifespan, it’s hard to tell from the pictures but one way to test them would be to jack the trailer up and if the wheels drop down as the trailer raises, they’ve got some life left in them. With no propane tanks, you don’t know that the water heater, furnace, stove or LP mode on fridge work. What is the date code on the tires? 5 years is about the cutoff for tire life. Do the holding tanks work/leak? Does the water pump work? I’d inspect any cubby or access panel to determine the health of the plumbing. Pex or copper supply lines? Also, it leaks... somewhere. They all do. Whether from the exterior or plumbing, there is a leak or two. Check the floor with an awl or ice pick particularly around the perimeter near windows, the door and access panels.
That said, value is up to you, but I’d think it’s a fair-ish deal especially for the size and layout. There are a lot of unknowns but since the seller is firm, it’s up to you. I’ve never heard of one, but it’s rarity doesn’t make it especially valuable, it’s size, condition and the market dictate that.
I like it, it’ll require work, but it looks fun.
Ian
Iansk is offline   Reply With Quote
Old 01-19-2021, 03:37 AM   #3
B. Cole's Avatar
1977 31' Sovereign
Rochester , WASHINGTON
It looks like a good project trailer.Its sitting good over tires.I would put some LTs on it.
If you plan on keeping it, it's not bad for a 25 yr old trailer.
Those smaller ones are the ones that sell quick.If you compare the price with a new SOB, that's a way more unique trailer, and much less $$$ in that length range.
If you look at what people are paying for (45 K?) those new sawed off / single axle 14 footers, or whatever they are, new Airstream Basecamps, thats way more trailer, for way less $$$.
B. Cole is online now   Reply With Quote
Old 01-19-2021, 08:44 AM   #4
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
These are very sought after units because of its short size and two axles - this one is a bit rough but assuming it has good bones is probably worth it - only thing that would turn me off to it is the dent in the back
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 01-19-2021, 09:07 AM   #5
B. Cole's Avatar
1977 31' Sovereign
Ken- I think "A bit rough" even describes a brand new Airstream sitting at a dealer with a 2-3 page punch list
As for the dent, it makes it look like it's been used as intended, like a pickup.
You're a vintage guy, you know what I mean !
Old 01-19-2021, 10:48 AM   #6
Napa , California
Anything is worth what anyone will actually pay for it. If you feel it is worth it, it is. Older "things" are harder to value and there can be so much hidden stuff to deal with that even a crystal ball won't help.
Does it have a clean title and can you check the vehicle records? Not that it will help. We once purchased a wonderful older used car driven by a little old lady who kept ALL the service records, had never driven on a highway and had lovingly had it detailed on a regular basis. A mechanic looked at, looked at the records and thought it was a great deal. And it was for a month or two until the engine died -at least it look cool in the driveway.
If you want it and if you think it is worth it, then it IS. If you are doubtful and hesitant, don't do it. And if you are waiting and thinking about it, our experience is that someone else will buy it just when you decide go for it.
Atwebs is offline   Reply With Quote
Old 01-19-2021, 12:09 PM   #7
1960 22' Safari
in the wilderness , The great Mojave Desert
Assuming you fit on the bed and in the "Throne room" comfortably.
I'd bring a propane tank and if all the gas appliances work. I'd probably go for it.
Nice size and two axles is a winning combination.
I'd rather be boon docking in the desert.
WBCCI 3344 FCU
AIR# 13896
CA 4
Yes, we have courtesy parking for you. About an hour North of Los Angeles.
Goin camping is offline   Reply With Quote
Old 01-19-2021, 12:35 PM   #8
The SilverSleeper
Beaubill's Avatar
2001 28' Excella
2005 25' Classic
1988 23' Excella
Daphne , Alabama
Cabinet doors.
Does the seller still have the cabinet doors ?
Beaubill is offline   Reply With Quote
Old 01-19-2021, 12:44 PM   #9
1994 21' Sovereign
Knoxville , Tennessee
I bought my 21 footer 4 years ago for that amount, it had the same issues, gross carpet, sagging headliner, a dent(much smaller), old drapes. I put in new flooring, wife made some new drapes, I half way fixed the headliner, put on four new tires and we have put about 15,000 miles on it. That is the perfect traveling size, easy to park and maneuver gas stations and it has big tanks. I bet you can find a couch for it out of a gut project.
Khale is offline   Reply With Quote
Old 01-19-2021, 01:14 PM   #10
rideair's Avatar
The real question becomes, "What can you afford to have in the trailer?"
Trailer 14K, New axles/tires 3k, Frig 2K, AC 2K, New couch/bed/curtains/etc 2K, etc... Now, you might get lucky and frig/AC work (for now), but you'd still have 20k in the trailer and that does not include water heater, pump, etc.. and can you do the work or will you be paying someone to do it for you? If you have to pay someone to do the work, add more dollars.
Its a great layout, I have a 1970 23' Safari Special that has the same basic floorplan.
Enjoy,
Paul Waddell
rideair is offline   Reply With Quote
Old 01-19-2021, 06:47 PM   #11
1981 31' Excella II
He has all the cabinet doors but one.
Old 01-19-2021, 06:49 PM   #12
1981 31' Excella II
How difficult was it to repair the sagging headliner? Did you redo with new vinyl padding and new adhesive?
Old 01-19-2021, 08:31 PM   #13
1994 21' Sovereign
You can’t glue it. A few strategically placed screws and white duct tape, not the best looking, maybe next winter I’ll do something nicer.
Old 01-19-2021, 09:31 PM   #14
mkcurtiss's Avatar
1968 26' Overlander
CORDOVA , TN
About $10,000.00, if everything works properly. If some system is broken, then it comes off the 10,000.00
Look at it his way....What will it be worth when you get everything fixed, and what will that cost you.....now put a value on your time, and be sure of one thing...whatever number you put on your time, it will not be close to enough....
If you think it will bring $30,000.00 all fixed up, then calculate it......but be realistic...as mentioned earlier, what something is actually worth is what someone will actually pay for it....
1968 Overlander Land Yacht International
Ford E-350 W V-10 booom!
2018 Chevy Tahoe smooooooth
Find a way to enjoy life and have fun, every day !
mkcurtiss is offline   Reply With Quote
Old 01-25-2021, 05:26 PM   #15
1995 21' Sovereign
Daphne , Alabama
Duke,
I have a 1995, 21’, Sovereign. I paid $9,000 5 years ago in Denver. 88 year old man put many dents in it. Interior was a time capsule, even the carpet. Ins totaled mine after a hail storm for $17,000 2 years ago. I took $11,000 and kept it. What you have is a money pit. Unless you do it yourself and then divorce is a possibility. Thinking I would pass on that. Value $8,000 in that shape.
My headliner is doing the same. Really a problem as you have to remove the furniture to make it “right”.
Best of luck.
tjansen is offline   Reply With Quote
sovereign
Please help me choose/value of used Airstream sylvia210 Trailer Values 1 01-13-2021 04:57 PM
Value Estimate? 1996 Excella 28' Classic outofcontrol Trailer Values 24 04-05-2013 12:37 AM
Newbie needs help on 1974 Sovereign value, please Tootuffy Buyer Guidelines 3 07-16-2012 07:05 AM
Help with value please godecals Trailer Values 3 07-29-2010 10:12 AM
What is a good value for a 1996 34ft Limited ? Davis Trailer Values 7 03-12-2008 10:21 PM
