Old 05-02-2017, 06:21 AM   #1
cyclistream's Avatar
Winter park , Florida
Water not working after connecting to the mains
Hi everyone my 1975 27 international overlander just came out of storage and first night could not get water to run after connecting to the camp water, immediately started flooding out from under the bumper, I disconnected. Then filled the tank and thought don't see no leaking, turned water pump on and not running at all and leaking under the back bumper again, does anyone know if I'm doing something wrong?
Every help will be greatly appreciated since we got 2 more stops to do before we arrive home in Florida
cyclistream is offline   Reply With Quote
Old 05-02-2017, 06:48 AM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
My 1st guess is a water line froze and burst over the winter. I know you are in Florida but did you winterize and did it get down to the mid twenties? Of course there are other causes for a broken pipe besides freezing. Likely culprits are water heater, city water pressure relief valve and just general plumbing. Your 75 has copper plumbing which is prone to freeze damage.
Old 05-02-2017, 06:57 AM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Low point drain valves open?
Old 05-02-2017, 07:02 AM   #4
I had in Canada in storage and they winterize it had it ready for the road haven't called them yet to ask but not it was prepared for the road
Old 05-02-2017, 07:03 AM   #5
Good question I don't know where's the low point drain valves are can you elaborate ?
Old 05-02-2017, 08:00 AM   #6
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Look to see where the water comes out. If there are small tubes or pipes extending below the coach. Verify they are the source of the water. Then go inside, look in that area of the coach, usually in a closet or cabinet. You should find the valves.
Are you getting water inside the coach?
Old 05-02-2017, 08:07 AM   #7
Long Island , New York
Ditto to good advice so far. When you hook up the city water hose, just crack the hose bib open slightly, and figure out where the water is coming from. You may have more than one leak. Calling the person who winterized is a good idea.
Please post new observations.
Good luck!
Peter
PS -- Does your old AS have a manual? Here is a possible one from 1975:
https://www.airstream.com/wp-content...0002.0110i.pdf
On p. 35 it talks about the winterization, drain valves, pump winterization, and so forth. [PDF p. 43/90]
What is your floor plan, does it have a center bath or not?
Old 05-02-2017, 10:32 AM   #8
dennis3751's Avatar
1976 29' Ambassador
Fitchburg , Wisconsin
In our 76 Ambassador the low point drains are in the rear and easily seen when the rear hatch is open.
Dennis
dennis3751 is offline   Reply With Quote
Old 05-02-2017, 10:48 AM   #9
Not inside outside only
Old 05-02-2017, 11:13 AM   #10
Pensacola , Florida
Cool no water
could the hose be clogged? from mulch or something?
Fran Ogden is offline   Reply With Quote
Old 05-02-2017, 11:41 AM   #11
1967 26' Overlander
Spartanburg , South Carolina
Dennis
Same is true of our '67 Overlander. When the valves are open the water comes out under the rear bumper. If it was winterized by draining and blowing out with compressed air the valves were probably left open. If it was winterized with RV antifreeze they probably opened the valves and drained the antifreeze out and flushed the lines with fresh water and left the valves open.
Jacob D is offline   Reply With Quote
Old 05-02-2017, 11:54 AM   #12
"Space A" S/O Registry 11
2006 34' Classic S/O
Fort Worth , Texas
Is there a outside spigot? If so,, make
Sure it is closed.
guskmg
Old 05-02-2017, 12:00 PM   #13
Please update us when you can, as the suggestions so far should help you narrow down the problem IMO.
Happy Trails!
Peter
Old 05-02-2017, 12:06 PM   #14
On the road now. Contacted dealership & awaiting reply. Lots to check out tonight.
Thanks for everyone's input. Will update ASAP.
Old 05-02-2017, 07:21 PM   #15
Thank you very much TG Twinkie and everyone your immediate replies make others want to be better in life OTRA15 thanks and dennis3751 we found it opening the rear hatch and there they are and felt they were opened and Click image for larger version
Old 05-02-2017, 07:25 PM   #16
Closed them and it's working fine and still waiting for place of storage to call me back lol if it wasn't for you I didn't have water now thank very much all
Old 05-03-2017, 02:45 AM   #17
Glad it worked out. Happy Trails!
Front interior light not working, middle and rear working? jonnyo Lights - Interior & Exterior 5 01-06-2020 11:25 AM
Electic Jack not working - fuse good - manual not working ryandanz Jacks, Stabilizers, Lifting and Leveling 20 04-24-2016 10:04 AM
Water leaking when connecting city water- mystery hose nozzle Romelio Fresh Water Systems 1 11-16-2015 06:01 PM
Furnace not working after several problem solving attempts Rikh Furnaces, Heaters, Fireplaces & Air Conditioning 3 11-24-2010 03:58 PM
Fridge issues - works on mains, but not on propane Yomster Refrigerators 11 08-03-2009 11:04 AM
