Old 04-19-2015, 01:55 PM   #1
1974 27' Overlander
Portsmouth , Virginia
Tom's 74 Overlander project
I bought this a couple weeks ago and have since gutted it out and pulled the shell off. The frame was near nonexistent as you will see from the pics. I used my Kubota tractor a C channel and a ton of wood blocks to jack the shell up, drive the trailer out, and then lower the shell to the ground to rest on 3 2x6 blocks high, just enough to get my floor jack under the edge. My plan is to fix this Airstream up as a vintage style party pad as a rental for weddings and other events.
Shell:
What was left of the frame, I kept the plywood deck boards and cut the rest of the trailer up.
Rusted out junk
Gutted inside except kept the end caps, I might leave them in there
Another gut shot
Front shell shot
tom p is offline   Reply With Quote
Old 03-28-2016, 06:06 AM   #2
Oxford , Michigan
Hello Tom,
I am working on my 74 overlan
Udodeschl is offline   Reply With Quote
Old 03-28-2016, 06:13 AM   #3
Oxford , Michigan
Sorry, hit sent
As I said. I am working on my overlander. I found a lot of rust in the bathroom area and decided to take the shell off. It looks like you have some experience and may be you have some advice for me
What is the best way to get the elevator bolts out?
How did you remove the belly pan on the side to get the shell off?
Do you have some picks on how you lifted the shell?
Udo
Old 09-08-2016, 05:50 AM   #4
Oxford , Michigan
Thank you very much everybody for the advice. I will cut most of it out and I will try to get it out as a small piece. If not I will drop the axel.
This project started as a just do some interior work. Then i took all the interior out, after that I found a lot of mouse crap. Now I removed the walls and the smelly insulation and I worked my way through a rust through back end. Which I get replaced tomorrow. I removed the belly. I guess I am at a point to replace everything and redo the whole trailer.
Old 09-08-2016, 05:50 AM   #5
Oxford , Michigan
Sorry wrong post. Was not meant for you
Tom Tom One GPS Version 3 wingfoot321 Electronics & Connectivity 11 01-08-2012 09:56 AM
Tom Hanks Airstream Moonshot Our Community 34 04-06-2009 12:38 PM
Tom at Perfect Polish airstreamcaravel Cleaning, Stripping & Polishing 1 09-16-2003 11:47 PM
