05-11-2019, 08:43 PM
#421
1966 24' Tradewind
1995 34' Excella
Lynchburg
, Virginia
David
Congratulations on the new beagle puppy. We got one in October. I hope you are a better dog trainer than I am.
Don’t overthink drilling the new axle holes. This isn’t your first parade.
Dan
05-12-2019, 04:57 AM
#422
2004 28' International CCD
1948 22' Liner
1963 22' Safari
Oakland
Whaaat? There was a question about axles?
Those puppy pictures distracted me. Sooo adorable!!!
David and Dan - Thanks for starting my Sunday off with a smile. Congratulations to you both.
05-12-2019, 07:21 AM
#423
1970 25' Caravanner
Incline Village
, Nevada
David. Could not agree with you more about those mounting plates. Dexter should default them as blank. I suggested this to Colin Hyde (whom I purchased through) but they didn’t give much of a response. Made me think if they are drilling them maybe there are plenty who use those holes.
05-12-2019, 01:34 PM
#424
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer
I must correct myself, the slots are 5/8" wide, not 3/4". Don't believe things you read on the internet!
David
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
05-12-2019, 06:21 PM
#425
1986 34' Limited
1975 27' Overlander
Conifer
Hole Saw From Hell
TouringDan: You are right. I've done this before, so just go do it and stop whining. I rechecked my measurements and chucked up the new Blair Rotabroach Aerowood recommended.
Broach may be a misnomer. I think of it as a hole saw from hell. It is much easier to use than a twist drill. I think it has maybe 8 cutting edges instead of a twist drill's two. See photo 1
The tool cut very cleanly and created an accurate hole diameter. I found it still takes a strong push on the drill to feed the thing through the steel. I have to hold and push the drill horizontally. I've got eight holes to drill, and I've got two of them done. Never start, never finish.
I had some trouble figuring out how to remove the steel "slug" from the rotabroach. It was stuck in there tight. I had to remove the guide pin and then punch the slug out from the back side. Not real handy. See photo
The rear hole is a "overlapping hole", one hole next to the other. Interrupted cut they call it. The rotabroach handled this operation very well. It would be nearly impossible with a twist drill. See front hole, rear hole photos
Location accuracy is a different story. That's my deal. Trying to layout a location from almost no reference is hard. As explained earlier, I used the bottom edge and leading edge of the stamped Dexter axle mount. My hole locations are about .020" off the slot centerline. Certainly not aircraft quality, but not terrible for hand held tools.
So I have several more hours of pushing this rotabroach through the axle plate and then grinding the holes to fit the slots. At least I'll get my axles up tight against the frame rails and then bolted tight so they don't fall off.
David
05-12-2019, 09:04 PM
#426
1966 24' Tradewind
1995 34' Excella
Lynchburg
, Virginia
David
Glad that you like the Blair Rotabroach. I also remember the difficulty in drilling the holes with a twist drill. I ordered the Blair Rotabroach in anticipation of installing 3 new axles in the 95 34’.
Dan
05-13-2019, 02:45 PM
#427
1967 26' Overlander
Haute-Aboujagane
, New Brunswick
I can't help with the axles but the puppy is adorable!
05-14-2019, 07:17 PM
#428
1986 34' Limited
1975 27' Overlander
Conifer
No axle mounting holes drilled today. I had to babysit the new puppy.
I don't think a beagle is trainable. All nose, no brain.
David
05-15-2019, 06:18 PM
#429
CC
1972 27' Overlander
Heinsburg
, AB
lol, tough day, eh?
CC
05-15-2019, 07:05 PM
#430
2007 22' International CCD
Corona
Worse, once that pup gets older and smarter he’ll find lots of ways to cause trouble. Some Beagles are too smart fit their own good.
05-16-2019, 06:22 PM
#431
1986 34' Limited
1975 27' Overlander
Conifer
We have a 10 year old beagle, who suddenly has a little step sister. Not a happy camper. Beagles aren't the smartest dog in the show.
Can't wait until we get them both in the Airstream for the next trip. Might be rather exciting.
No axle holes drilled today either.
David
05-21-2019, 05:55 PM
#432
1986 34' Limited
1975 27' Overlander
Conifer
Axle Holes Drilled
Springtime in the Rockies. We had about a foot of heavy wet snow last night.
It's been a long winter. The snow fall is welcome moisture however. The Memorial Day cookout may have to be inside.
I now have all 8 new holes drilled in the axle plate. And I have all 8 new bolts installed. The axles are up.
I elected to install a 1/2" steel bar between the frame rail and the axle bracket. I did this because the original U notches in the axle plate were not deep enough to allow the axle bracket to rest tight on the frame rail. It must rest tight on the frame rail with no weight on the axle bolts. I could grind the U notches deeper, or I could add this steel bar to the frame rail. I felt a 1/2" lift will not significantly upset the balance or the appearance of the Overlander. In fact, it will help a bit here in Colorado campsites. The new beagle puppy approved.
I have the new shocks to bolt up. I can do this with the axles in place. I also have the brake wires to connect and verify they all work as intended.
It will be nice to get the Overlander on its wheels and tires soon.
I still have a quite long list of things yet to complete. I'm many hours from the maiden voyage, but closer than I was a year and a half ago.
David
05-21-2019, 11:09 PM
#433
1970 25' Caravanner
Incline Village
, Nevada
David. We got the same snow last night. And again tonight. Just in time for Memorial Day weekend. Good mod on the gap for the axle mount. Glad you got those holes drilled without injury.
1.5 years. You and I started about the same time. I'm so close to heading out. Just some here and there items left. Good luck
05-22-2019, 08:11 AM
#434
1972 31' Sovereign
Lexington
Come to Minnesota for Memorial weekend. We're supposed to be in the '70's with possible thunder shower lurking. For us, can't get better than that!
Kay
05-22-2019, 06:46 PM
#435
1986 34' Limited
1975 27' Overlander
Conifer
I bet the walleye and bass fishing will be good too. I miss Minnesota.
David
05-23-2019, 07:50 AM
#436
1972 31' Sovereign
Lexington
Hold the phone! They changed the forecast (what a shock). Thunderstorms tomorrow. Wait till Saturday to come! Supposed to be a cooler and rainier than normal summer here.
Kay
05-24-2019, 07:39 PM
#437
1986 34' Limited
1975 27' Overlander
Conifer
Brakes Work
I installed the new shocks and wired up the brakes today. Good brakes are important for the way I drive. I'm sure you would agree.
I tested for 12v at each of the 4 brake wire runs before I installed the insulation, belly pan and axles. All present and accounted for. I was hopeful I did not disturb any connection during all that commotion. Lucky for me all 4 brakes lock solid when I pull the break away switch. (brake away switch?) It would be a super big project to get at the brake wires under the belly pan at this point.
Okay, cross off new axles, bearings and brakes of the improvement list. The two new axles are the most expensive line item I have purchased at about $1700. The new fridge is second at $1100. I will have the new axles professionally aligned before any long trips.
David
05-25-2019, 11:21 AM
#438
1966 24' Tradewind
1995 34' Excella
Lynchburg
, Virginia
David
David- I was not aware there was any adjustment possible allowing the axles to be aligned. What is the alignment spec?
Dan
05-26-2019, 06:55 PM
#439
1986 34' Limited
1975 27' Overlander
Conifer
Hi TouringDan: The specs for alignment are toe in of about 1/16" and camber about 3/4 degree positive. Trailer shops who distribute Dexter axles generally have the equipment to align them to spec. The adjustment is actually bending the axle tube for camber and toe. They also check to ensure the axles are perpendicular to the trailer frame.
I drilled 5/8" diameter holes for 5/8" bolts. I had to file to get the bolts into the holes. They fit pretty tight. It may be I would have to enlarge a axle bolt hole in order to get the axles square to the trailer. I have no good way to measure this.
Once my Overlander is ready to tow, I will make an appointment to get the axles aligned.
David
05-27-2019, 10:21 PM
#440
1966 24' Tradewind
1995 34' Excella
Lynchburg
, Virginia
David- Amazing! Thanks for the education. I would think that the axles as installed would surely be perpendicular to the frame assuming that Airstream put the axle slots in the correct location.
Dan
