Old 06-16-2021, 12:24 PM   #1
jw21id's Avatar
2001 25' Excella
Spokane , Washington
Main battery - curb side or street-side?
I have a 2001 Excella 25 that my wife & I bought last fall and just purchased 2 batteries to replace the older existing ones. Which is the main battery, curb side or street side?
2001 Excella 25
2000 GMC 2500 Classic 4x4, 5.7L
jw21id is offline   Reply With Quote
Old 06-16-2021, 12:37 PM   #2
Sag Harbor , New York
Good move to bounce over to this sub-forum.
What does your owner's manual say? Is there a battery selection switch for 1, 2 or both?
Peter
Let the music lift you up . . .
[Robert Frost reading live -- 2 minutes]
OTRA15 is online now   Reply With Quote
Old 06-16-2021, 12:53 PM   #3
1986 31' Sovereign
Miami , Florida
They are wired in parallel so there is no “main” battery.
Sorta new (usually dirty) Nissan Titan XD (hardly paid for)
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
Old 06-16-2021, 12:57 PM   #4
jw21id's Avatar
2001 25' Excella
Peter - best I can come up with from a wiring diagram in the manual is that they must work in conjunction with each other, although it does list the second battery as being additional, even though I connect each one in its tray. One of the new batteries has slightly more reserve capacity, that's why I was wondering which could be the main one.
Checked the coach, just have the battery kill switch. No indicator behind the sofa against front wall in regards to battery # 1 or # 2.
2001 Excella 25
Old 06-16-2021, 12:59 PM   #5
jw21id's Avatar
2001 25' Excella
Thanks Mike!
2001 Excella 25
Old 06-16-2021, 02:18 PM   #6
Thumbs up
Thanks for the updates . . . happy trails!
Peter
Old 06-16-2021, 03:12 PM   #7
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
The batteries should be matched in age and capacity. I have no idea what happens if they are not. I have always bought them in pairs.
Old 06-16-2021, 03:18 PM   #8
Battery School
Jim this Battery School is good general background reading FYI.
http://www.batteriesnorthwest.com/batteryschool.cfm
Peter
FYI
FWIW
Old 06-17-2021, 04:20 PM   #9
:SPACE A" S/O 11 Air19745
guskmg's Avatar
2006 34' Classic S/O
Fort Worth , Texas
Here are some handy tips on batteries: If left in parallel the stronger battery will discharge to the lowest battery. That's why individual master switches are use in marine applications. Or use a switch you can select either one or both. Having said that, if you leave them in storage with both off, one won't effect the other. However, if both were adequately de-sulfated they would read the same resting voltage anyway. Now for the confusing information. Several years ago GM determined that in parallel situations the batteries will not be harmed if they have different levels of resting charge and are of different ages. My Duramax GM has beed through 6 different batteries only changing out one at a time. They all have lasted 5-6 years which is normal for these batteries. Now, Interstate says that when you charge batteries in parallel to place the charger positive clamp on one battery and the negative clamp on the other battery for equal charging. Just in case you haven't hear all this info. It can be most confusing at best.
guskmg
Main battery - curb side or street-side? jw21id Batteries, Univolts, Converters & Inverters 1 06-16-2021 12:34 PM
Curb side vs Road side for replacement part Cvinson 2005 and newer - Bambi all models 3 03-18-2021 12:57 PM
Wing Window curb and street side temp glass 1970 to 1983 Spookies Airstream Classifieds 0 08-13-2017 04:01 PM
Steps fought the curb and the curb won badkat Airstream Lifestyle 13 06-22-2013 02:03 PM
1755 Main Street Manufacturing Tag PeeWee WBCCI Forum 6 09-22-2007 10:14 PM
