Old 06-08-2024, 08:57 AM   #1
LRichmond's Avatar
HELP Lost Wire
Hi All,
Need help FINDING wire. HISTORY: Thought that I would change out propane alarm on my 2000 34' Excella. After removing unit from wall, I did something VERY stupid, I CUT THE WIRES WITHOUT SECURING THEM FROM GOING BACK INSIDE THE WALL!!!. Only the ground wire shot back into the wall and I was able to fold back the hot wire.
Now the problem is trying to find the ground wire. Original hole is only about 3/4" and located about 12-18" above floor. No way to 'look' and see where the ground wire is. I have removed a small piece of baseboard trim that is under the hole and at the moment "thinking" about cutting another hole closer to the cabinets to see if the wire is lying there and 'fish' it out
Unknown is the wires drop down from above or if they are lying on bottom from sidewall.
ANY GOOD SUGGESTIONS????
Thanks in advance
Lawrence
LRichmond is offline   Reply With Quote
Old 06-08-2024, 06:25 PM   #2
2019 30' International
Pennsylvania , Pennsylvania
https://www.amazon.com/endoscope-cam...doscope+camera
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 4:30 rear Leer Topper Ruby Red
2019 International Serenity 30 Rear Twin
majorairhead is offline   Reply With Quote
Old 06-08-2024, 06:39 PM   #3
2023 Interstate 19
Browns Valley , California
You can even get an endoscope with a grabber on the end:
https://www.amazon.com/dp/B07Z8SQ6T5/
Good luck!
JimMartin is offline   Reply With Quote
Old 06-09-2024, 12:31 AM   #4
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
A less expensive but equally useable grabber for blind fishing:
https://www.amazon.com/Flexible-Grab.../dp/B0CJ8QNGQP
Sir Tristan
Air #48582, S/SO #003, WBCCI #4584
SeeMore is offline   Reply With Quote
Old 06-12-2024, 07:55 AM   #5
LRichmond's Avatar
Help! Lost Wire
Originally Posted by LRichmond View Post
Hi All,
Thanks in advance
Lawrence
A BIG Thanks to ALL for the advice.
I got a 'snake' camera, however I didn't want one that goes to the phone, so I got this:
https://www.amazon.com/Dual-Lens-End...ef_=ast_sto_dp
Would NEVER have found the wire without it. It comes with a small magnet and a hook, however the hook is junk. It did work to snag the wire, but snapped as I was pulling it thru the hole. Also, has a side camera on the head.
Wire that I was looking for had ALMOST slid under the shower pan.
Again, THANKS
Lawrence
Lost 12vDC to Fantastic Vents, A/C - mystery wire routing JimAspinwall Lights - Interior & Exterior 5 08-02-2021 08:24 AM
Lost running light wire Seawway Lights - Interior & Exterior 8 08-01-2018 05:11 AM
Turn Signal Wire lost continuity woliners Electrical - Systems, Generators, Batteries & Solar 21 10-21-2014 07:27 AM
Lost wire to running lights Steve & Susan 2002 - 2005 International 5 05-07-2012 08:22 AM
Wire ,wire, oh wire can it be ? 69 Silverback Electrical - Systems, Generators, Batteries & Solar 8 05-15-2003 11:09 AM
