Old 10-20-2017, 11:57 AM   #1
Excellent
2000 30' Excella
Paris , Ontario
fridge not switching to electric
Just got this trailer less than a month ago. It will not switch from gas to electric.
any ideas
sgnen is offline   Reply With Quote
Old 10-20-2017, 12:58 PM   #2
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
3 things I can think of:
1. The fridge is set to LP mode and not ‘auto’ mode so it is forced to use gas. Check the LP/auto switch accordingly
2. 120v breaker is tripped and the fridge is not receiving 120v power. Check your shore power breakers accordingly
3. Long shot - The fridge is not plugged into 120v outlet power. Check the external fridge access door outside the trailer and verify that the fridge is plugged in
Let us know what you find based on the above
wulfraat is offline   Reply With Quote
Old 10-20-2017, 01:21 PM   #3
richw46's Avatar
Lexington , Kentucky
Also, check the plug, make sure the contacts are clean on both the plug and the wall socket. My socket had dirty contacts, the fridge would run for a while then stop. I had the propane turned off so it didn't cut over, I just got the error light. Removed the wall plug (120 disconnected) and cleaned it with WD-40 and contact cleaner. I also pinched the socket copper connectors to put more pressure on the plug. Put it together again and it's running like a top again.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
Most of us don't know exactly what we want, but we're pretty sure we don't have it. -Alfred E. Neuman
richw46 is offline   Reply With Quote
Old 10-20-2017, 05:47 PM   #4
Excellent
2000 30' Excella
Paris , Ontario
thanks for the info. I will check it out and let you know
Old 10-20-2017, 06:27 PM   #5
Dan and Liz's Avatar
1987 25' Sovereign
Fort Collins , Colorado
OR -- have a nuclear sub electrician like my buddy who knew which relay to whack on the board to wake it up ...
Alumacoot
“We are confronted with insurmountable opportunities.”
Dan and Liz is offline   Reply With Quote
Furnace not relighting after switching propane tanks bradleyoder LP Gas, Piping, Tanks & Regulators 24 10-17-2015 01:38 PM
Switching on the Electric Knob CordellCampr Refrigerators 0 04-16-2015 06:44 AM
heat pump not switching to furnace Alumitater Furnaces, Heaters, Fireplaces & Air Conditioning 5 02-01-2014 06:20 PM
Need Fridge...can Solar keep up with an Electric Only Fridge??? chowman2011 Refrigerators 13 05-17-2011 08:59 PM
Electric or Gas electric fridge replacement?? tin can luv Refrigerators 26 03-22-2004 09:50 AM
