Old 09-27-2020, 08:35 AM   #1
1999 28' Excella
Rowlett , Texas
Send a message via Yahoo to richardjohnsonlaw
Convert to 50amp
I have a 99 Classic 28 foot that I am considering adding a second a/c but need to convert to 50 amp. Is that a complicated or expensive process? I also need to replace the a/c heat pump. Any recommendations?
Richard P. Johnson
richardjohnsonlaw is offline   Reply With Quote
Old 09-27-2020, 09:04 AM   #2
Airstream Driver
PeterH-Airstreamer's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 51
You can also add another 30 amp service for the second AC and use a 50 amp to 2x30amp splitter. I always add a 30 amp breaker box inside the trailer for this conversion.
1992 350LE Classic Motorhome
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 09-27-2020, 09:33 AM   #3
Airstream Driver
1994 30' Excella
Images: 51
Here are two input options for you to considered if you go this route:
The first is a 20 amp twist on that will need a step down adapter from 30 to 20 amp
The second is a 30 amp that can be connected directly to the 30amp splitter via the right extension cord. This option would be desired, since it would let you add additional outlets in the bedroom without taking away from the factory 30amp feed, which is already close to being maxed out with AC, converter etc.
ID:	379585   Click image for larger version
AIR #13
Old 09-28-2020, 08:32 AM   #4
1999 28' Excella
Rowlett , Texas
Heat pump recommendation
I need to replace my worn out heat pump/ac on my 28 foot Classic. Currently have Dometic Penguin. Is this still a good choice for replacement? It never got the rear bedroom cool on hot days.
Old 10-05-2020, 03:58 PM   #5
Ultraclassic's Avatar
2000 30' Excella
GTA , Ontario
How did you make out? Our old unit worked fine for us we had a lot of 30c days this summer
Tow Vehicle 2005 Ford F150 Lariat 367,000Kms 5.4L - 2012 Mercedes Benz GL350d - [not set up yet, should i?]
Ultraclassic is offline   Reply With Quote
Old 10-05-2020, 04:34 PM   #6
jeffmc306's Avatar
2019 27' Globetrotter
McHenry , Illinois
Hello Richard,
We have 50A service in our 2019 Globetrotter so I pulled some pages from the owner manual’s electrical section that might help answer your question about what’s involved.
Fifty amp service is really two 50A legs compared to one 30A leg. This allows you to distribute the power between two 50A main breakers so one AC unit will be on one side and the 2nd on the other side.
You’ll need to replace the supply cord, external connector on the outside of the trailer and the wiring from the back of the plug to the breaker panel which also needs to be replaced to handle the dual 50A feed. You probably want to replace the circuit breakers unless the original ones are the same type as the new panel’s.
Once you have the new panel installed you can pull wires to the 2nd AC unit. See the 50A service drawings below for a better idea. It’s not difficult work just time consuming as long as you’ve got electrical skills.
Good luck!
Jeff
ID:	380159   Click image for larger version
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
jeffmc306 is offline   Reply With Quote
Replacement 50Amp Cable JourneytoRet Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 2 04-08-2013 06:03 AM
50amp Conversion / Addition TomR Electrical - Systems, Generators, Batteries & Solar 6 11-03-2007 12:07 PM
50amp for 30amp trailer? racoco Electrical - Systems, Generators, Batteries & Solar 15 08-24-2007 07:43 PM
Power Inlet 50amp markdoane Electrical - Systems, Generators, Batteries & Solar 4 10-14-2005 08:25 PM
30amp to 50amp? alfalsetto Airstream Motorhome Forums 17 08-16-2003 06:42 AM
