Old 04-28-2021, 07:16 PM   #21
1992 25' Excella
Atlanra , Georgia
You'll love it, we have a 92 Excella n Ford 250. Visit TOP of Ga in Helen n meet your extended family. Happy travels n be safe
judi sells is offline   Reply With Quote
Old 04-29-2021, 04:39 PM   #22
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
Seems that the brakes situation has been resolved - they are simply going to issue a full refund on the brake work. Normally they would have sent out a field tech to do an on-site repair, but since I'm nearly 900 miles away that's just not practical. Since I have no desire to drag it back to them without brakes, this seems like a fine solution.
I was planning to order axles this summer. They were going to be bare axles since I just had the new brakes put on, but since the brakes need to be redone now I'll just put the refund towards getting the axles shipped complete with completely new brakes. Guess it all works out in the end.
In other news, an hour or so scrubbing down the cabinets and walls tells me that it's going to take many more hours to thoroughly clean the interior. I'm guess someone smoked inside at some point and caused a layer of sticky residue which is going to take some effort.
1994 Excella 25
1974 GMC 4108a - Custom Coach Land Cruiser
richard5933 is offline   Reply With Quote
Old 04-30-2021, 04:11 PM   #23
1994 25' Excella
Interior Work Has Begun
I got started on the interior today. The first steps will be doing a thorough cleaning to de-stinkify it from the cigarette smoke residue, spilled 'freshener' in the bathroom, and general funkiness. I'm thinking that the mouse fur on the walls and the carpet is hold the odors, so I'm working to expose as much of it as possible for a thorough cleaning.
The next step is replacing the wallpaper in the kitchen and bathroom. Took a couple of hours to strip it down to where I think I can start stripping, cleaning, priming, and finally repapering the walls.
We've decided to keep the carpet for now. It's not our style but it's in great condition and will clean up nicely. I did peel back some carpet around all the edges, and other than a little minor discoloration here and there from condensation I cannot find any damage to the plywood from moisture. With this known, tearing up the floor isn't as high a priority as it once was.
It looks like we're going to get things cleaned up, do the wallpaper, hang new drapes, get new mattresses, and then hit the road with essentially a stock 1994 Excella. After we spend a few long trips in it we'll know better what we'd like to change moving forward.
Mechanically I'll be installing a pair of 3500-lbs #11 axles, complete with new brakes. A little bit of rust removal & repainting should wrap up the structural issues.
On the electrical front, I'll be replacing all the marker lights, installed a modern multi-stage charger, and that's about it. I've got a 2000-watt PSW inverter sitting on a shelf, so I might install it up front next to the batteries and connect it to the main electric panel via a new manual transfer switch in the bedroom. That would give us the ability to use the microwave and such. Eventually I think we'll be installing a hybrid inverter/charger so that we can run the a/c off a small 2000w Honda generator by having the inverter kick in with a power boost from the batteries as needed.
Okay, enough dreaming...here are a few photos of the work in progress.
ID:	394537   Click image for larger version
1994 Excella 25
Old 04-30-2021, 06:19 PM   #24
1966 22' Safari
Fredericksburg , Texas
Brings back memories. We helped a friend of a friend last year get his 89 Excella back on the road after sitting for 12 years. Replaced the PB piping with PEX, installed an on demand hot water heater and a new Progressive Dynamics converter. He had a guy replace the axles and a few other things. They hit the road. You’re putting a lot of thought into it and doing a great job. It’ll be around for a long time. Good luck and enjoy.
Bubba L is online now   Reply With Quote
Old 04-30-2021, 07:09 PM   #25
1994 25' Excella
Tell me more about the PB plumbing. This is the second time recently someone mentioned it to me. I've got the gray plastic plumbing with hard copper fittings, which I assume is the PB stuff. What's the problem with it? How do you know when it's time to swap it out?
1994 Excella 25
Old 04-30-2021, 07:31 PM   #26
1966 22' Safari
PB piping stopped manufacturing in 1996 due to lawsuits concerning pipe failure. The pipe reacted to oxidants in tap water and the pipe wall deteriorated. This caused breaks in the pipe. There is a Sharkbite fitting that transitions from PB to PEX. The guy we know had numerous leaks in the PB so we removed what we could get to and replaced.
Old 04-30-2021, 09:18 PM   #27
CRH
1995 25' Excella
xxxxx , xxxxxx
You can also get a Pex crimp on fitting to transition from PB to Pex.
CRH is offline   Reply With Quote
Old 05-13-2021, 04:24 PM   #28
1994 25' Excella
I've just about got all the wallpaper removed from the wood partitions. I'm planning to leave the stuff stuck to the aluminum in place, as it's stuck well and in good shape. I'll just scrub it down, and then all surfaces will get a coat or two of wallpaper primer before I apply the new self-adhesive wallpaper.
Having such fun discovering all the places mice leave their tiny turds.
1994 Excella 25
Old 05-15-2021, 02:54 PM   #29
1994 25' Excella
Wallpaper is going up...
And here's the start of the new wallpaper. Nothing fancy - just some self adhesive paper from Home Depot. But, the pattern will work with the current interior and our plans moving forward. It also hides a multitude of sins.
1994 Excella 25
Old 05-15-2021, 06:17 PM   #30
1994 25' Excella
Progressing nicely. It actually looks much less chaotic in person. Click image for larger version
1994 Excella 25
Old 05-16-2021, 07:12 PM   #31
1994 25' Excella
Wallpaper completed - bathroom's new look...
Wrapped up the wallpaper today. Bathroom came out really great and we're really happy with the upgrade from the old-time factory stuff.
1994 Excella 25
Old 05-21-2021, 03:57 PM   #32
1994 25' Excella
Door gasket removal sucks...
Spent the day removing door gaskets from both the entry door and the screen door, and all I can say about it is that it's a pretty miserable job. Finally had to break out the lacquer thinner to get all the remaining adhesive off.
Now have a new gasket on the screen door. Nice. The old one had turned to dust. New screens finished that off nicely.
Entry door gasket is on order, and hopefully will go in easier than the old one came out. It was still in good condition, but was not the correct one and allowed water through.
1994 Excella 25
Old 05-21-2021, 09:57 PM   #33
1982 27' Excella
Harrisburg , Oregon
I've got to clean the old adhesive off my screen door and replace the foam gasket too. I'm not looking forward to that job. I've got the solvent and the gasket material on hand... I've just been dragging my feet about starting it. I should do that tomorrow, and just get it out of the way.
Scott
skucera is offline   Reply With Quote
« Emblem Restoration | Top | - »
The adventure begins.... in more ways than one! katzklaw 1960 - 1964 Overlander 157 12-21-2014 03:54 AM
Our full time adventure begins on Monday! zombyw00f Full-Timing 18 12-13-2007 09:38 PM
"The Tube's" Adventure Begins myboyburt Cleaning, Stripping & Polishing 44 07-11-2006 02:50 PM
A New Adventure Begins jpurdy Off Topic Forum 26 08-29-2004 12:00 AM
Off to LA....The Adventure begins JodynJeep On The Road... 29 11-20-2003 12:23 PM
