Old 11-22-2021, 09:16 AM   #1
Houston , Texas
Replacing toilet but what is going on here?
I have a '91 Excella Classic 1000 34ft trailer.
I am replacing the Thetford Galaxy Starlite toilet with a Dometic 320. In my attempt to do this, I removed the factory carpet from the bathroom because I am planning to get rid of all that, and carpet near a toilet is just plain ridiculous. There is no platform for the toilet, it just sits on the floor.
To my questions and concerns:
The Thetford mounting bolts are at 11 and 5 o'clock on the closet flange. I supposed I could unscrew it from the wood floor and twist it around to get that aligned for the Dometic 9 and 3 positions.
I am not sure if the flange is glued down though, but it seems like some solutions people have posted here should that be the case is to use a multi-tool and grind in slots in lieu of unscrew/rotate. Anyone have an opinion?
My main concern though is the way the flange is situated. There is no "funnel" part of the flange to direct the flow into the black tank. The plywood is totally exposed as I see it. I did notice the old toilet has a smaller opening at the bottom which seems like the same size as the current opening. However, the Dometic opening is definitely larger, enough to obviously splash the flow on the way down.
*What is going on here? Was there some replacement to a different flange in this trailer's past? The flanges I see to purchase for Airstreams show either a funnel or a threads to screw into the black tank.
* The plywood looks like OSB and not marine plywood. Is this the way the wood should look like in this location? The carpet to me is the original carpet because I had to cut it out so replacing the wood would have required some work on that to have effected a change.
*Can someone help me understand if there is a flange I should be using instead of the current one and/or should I be concerned at all and just bolt the new toilet and flush on? My gut tells me that hole size is too small to leave it that way. Here is what I think I should have installed as it provides a funnel action into the black tank and protects the wood from exposure of the incoming.
Name:	Toilet flange.jpg
Name:	toilet flange 2.jpg
More Pics:
pic 1 - This is the current situation with markings showing the Thetford and Dometic alignments. It also shows the flange and the hole through the plywood.
Name:	1 - Flange.jpg
pic 2 - This shows more detail of flange and the hole to the black tank. Seems like there is a 1/4" plywood on top of the base marine plywood that looks 7/8" to 1" thick.
Name:	2 - holey.jpg
pic 3 & 4 - This is a close up view of the flange with measurements.
Name:	3 - inner flange size.jpg
Name:	4 - hole size.jpg
pic 5 - These are measurements of the Dometic toilet.
Name:	5 - Dometic.jpg
pic 6 & 7 - These are the measurements of the Thetford toilet.
Name:	6 - Thetford outer.jpg
Name:	7 - Thetford-inner diameter.jpg
Buy once, cry once.
jokila is offline   Reply With Quote
Old 11-22-2021, 09:43 AM   #2
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
Are you sure that the white-ish ring inside the flange isn't part of the flange and not the sub flooring showing through? Almost looks like they built that flange by bonding an inner ring of white plastic to the black plastic outer flange.
Richard
11018
richard5933 is offline   Reply With Quote
Old 11-22-2021, 10:02 AM   #3
1988 32' Excella
Robbinsville , New Jersey
Airstream switched to OSB in the 80's and then back to plywood in the 90's. I don't know the exact years, probably varied by model. My flange is threaded and is screwed into the tank plus the screws around it into the OSB, no glue.
Old 11-22-2021, 10:32 AM   #4
Houston , Texas
That light colored part looks like wood and the hole is off-centered from the black flange. If it were part of it, it wouldn't be so obviously misaligned in my opinion. I plan to remove the black flange and see about realigning it for the Dometic pattern. I will definitely know by that point how it is configured.
That explains the OSB as my friend's 2000 34ft Excella is marine board covered in linoleum, but I don't have the opportunity to remove their toilet for a peek at the flange situation. Seems odd that mine is not either screwed in or funneled down in some sort of slip joint into the black tank.
Here is what I see I can possibly buy for my need. The hub G version looks like what I might need but looks like there is some fabrication of the flooring involved, something I would rather not do unless absolutely necessary.
https://vintagetrailersupply.com/toi...lange-vts-736/
Buy once, cry once.
Old 11-22-2021, 11:22 AM   #5
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
It looks to me like you have part of the old Tetford toilet broken off in the flange. Been a while since I replaced mine but the pipe on the bottom of the toilet is supposed to extend through the flange.
Bill M. is online now   Reply With Quote
Old 11-22-2021, 11:25 AM   #6
1994 25' Excella
This, or perhaps it's some other type of PVC fitting someone used in a past toilet swap to try and solve some leaking/sealing problem. Looks much more like rotting PVC than wood.
Richard
11018
Old 11-22-2021, 11:34 AM   #7
Houston , Texas
Refer to the last two pics of the bottom of the Thetford toilet in my post. There is nothing broken off the toilet. The only thing I removed from the toilet before i took a pic is the seal.
Thanks for the feedback. I have not seen rotting PVC before, but I will be removing the black flange to get a better look at the floor. From inspecting the hole I see a 1/4" layer of OSB, then about 3/4 to 7/8 of marine plywood. My 2nd pic shows the layers. I didn't want to poke at it just yet, but will be doing a more extensive analysis of the material.
Buy once, cry once.
Old 11-23-2021, 09:35 AM   #8
1988 32' Excella
Mine looks like version B in that link.
Old 11-23-2021, 10:07 AM   #9
1988 25' Excella
1987 32' Excella
From the factory the subfloor is OSB about 5/8” thick. There is no marine plywood or other flooring. There may be pieces of styrofoam above and below that he tank as a spacer.
Old 11-23-2021, 11:47 AM   #10
88Limited's Avatar
1988 34' Limited
Mobile , Georgia
That does look odd. I've had our floor/toilet in a similar situation and the flange is screwed into the tank and then secured to the floor. It almost looks like whatever that material is inside the flange, it's been inserted and glued in. I would try unscrewing the flange and twisting it out and see what you get.
Edit: I wouldn't leave it like it is, especially with the size difference between the toilet outlet and whatever is inserted into the flange. You'll be asking for solids to get stuck and a blockage to happen.
88Limited is offline   Reply With Quote
Old 11-23-2021, 02:55 PM   #11
:SPACE A" S/O 11 Air19745
guskmg's Avatar
2006 34' Classic S/O
Fort Worth , Texas
Be sure and clean off the ring where the flange to floor screws are located. I missed one and that causes anguish and frustration. Then use an oscillating tool to cut slots on each side of the flange and insert a piece of steel and turn with an adjustable wrench. Easy peasy if you impact the make do spanner wrench toward the tightening direction first. Airstream use sealant on my threads and that complicates the process some.
guskmg
Old 12-08-2021, 10:56 AM   #12
Houston , Texas
Follow up on this. You were on to it.
What was going on is the flange was was covered in some sediment that resembled the floor. I have not used the toilet since I have owned the trailer so it's whatever was dried up from the PO's time with it. Also, the flange's downpipe looked a bit off-center (which it wasn't after all) which led to me assuming it was the floor. I took a wire brush and found the sediment came off enough to show the flange goes into the black tank.
I removed the screws and easily turned it using the toilet mounting bolts as the holding part. I moved it about 15 degrees or so and was able to make the slots line up at the 9 and 3 positions. The mounting holes for old position worked for 4 of the bolts and i drilled pilot holes for the rest. I made sure I did not go through the plywood with the drill to avoid drilling into the black tank.
Good to go.
Buy once, cry once.
Old 12-08-2021, 11:30 AM   #13
1994 25' Excella
Good to go.
Yay! So happy it worked out so easily for you.
Richard
11018
Replacing toilet but what is going on here? jokila General Repair Forum 5 11-22-2021 10:13 AM
Replacing toilet but running into flange problems stylistown Sinks, Showers & Toilets 0 11-02-2015 02:43 PM
Replacing old platform toilet with "regular" toilet? Mrs.S Plumbing - Systems & Fixtures 4 11-21-2011 03:52 PM
mb 52 C going going...... goransons Refrigerators 5 08-23-2007 03:51 PM
