Old 01-27-2021, 06:17 PM   #1
1992 25' Excella
Sachse , Texas
Patching my Exterior Range Vent
My exterior range vent needs to be replaced and I need to remodel the kitchen area. I was thinking of pulling out the vent-a-hood and just putting the patch over the exterior vent. I think I've heard of others just relying on their main fan in the ceiling. What do you guys think?
Goondog is offline   Reply With Quote
Old 04-09-2021, 06:14 AM   #2
Re-Pete's Avatar
1992 29' Excella
Virginia Beach , Virginia
I'm going through the same dilemma. I still have not made a decision. I purchased a very expensive exterior stainless steel range vent replacement (for the original plastic one) from Out of Doors Mart. I don't like it at all so I won't be using it. We live in our 92 when it's not in dry dock and I'm not sure I'd want to vent that much cooking through the front ceiling vent. Something to consider though. To bad there isn't more input on this.
Pete
Virginia Beach, VA
1992 29' Excella Classic
TV 2006 Dodge Ram 2500
Mega Cab Diesel 4x4
Re-Pete is offline   Reply With Quote
Old 04-09-2021, 08:03 AM   #3
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Our closest vent is about 6 ft away from the range. I wouldn't want to rely on it to vent the stove. And, what if it's raining? The advantage of a range hood is that you won't get rain in if you need to vent. I would go with a range hood, personally.
Kay
Old 04-09-2021, 10:14 AM   #4
Re-Pete's Avatar
1992 29' Excella
Kay
We're doing a rebuild, so we've installed the new MaxAir fans, front and back, so, even open they are shielded from rain, but like you said it's several feet away.
I painted our OEM plastic vent silver in 2017 when I polished the exterior, and honestly it still looks fine, and it doesn't leak at all. Still, it's 29 years old. The Stainless Steel replacement is unusable in my opinion. Because of it's design it will leak and I can't see a way to fix that without constant maintenance. In my opinion it's just not well crafted for an Airstream. I'm probably going to buy another plastic one, paint it silver, unless it come in gray now, and stick that on. If it also lasts as long as the OEM, it will have done it's job and then some.
Pete
Virginia Beach, VA
Mega Cab Diesel 4x4
Old 04-09-2021, 10:31 AM   #5
2019 27' International
Western NC , North Carolina
I just installed the stainless vent on our 27, the key is there is a special set of gaskets you need to order which fit in the gap that goes against the aluminum skin.
So far no leaks.
2023 Van Leigh Vilano 320GK
2019 International Serenity 27 FBQ “TC Escape” SOLD
2019 Ford F-350 Platinum
JonDNC is offline   Reply With Quote
Old 06-17-2023, 02:41 PM   #6
Re-Pete's Avatar
1992 29' Excella
So far no leaks.
I know you post is a few years old. I also got the gasket kit with the Stainless Steel Vent cover, but they were not adequate to create a proper seal. Maybe I'm doing it wrong. I'm still able to use it if I decide to. Are you able to post some pictures of the install.
Pete
Virginia Beach, VA
Mega Cab Diesel 4x4
spackle & paint make what it ain't: patching the Fan-tastic vent garnish Bob Blarney Upholstery, Blinds, Walls & Interior Finishes 3 07-08-2018 07:36 PM
Exterior Range Vent Cover airsuccess General Repair Forum 0 06-09-2014 08:55 AM
'78 Sovereign Exterior Range Vent Cover rockcampbell Roof Vents, Skylights & Fans 3 07-12-2013 04:02 PM
Replace range/oven with range/microwave rkconway Stoves, Ovens & Microwaves 2 01-13-2009 03:58 PM
