Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 02-26-2003, 01:12 PM   #1
1999 25' Safari
Edina , Minnesota
Solar Panel Mounting
The Shell solar panel I just got has pre-drilled mounting holes. I intend to mount the panel flush (flat) with airspace underneath. What is the best way to mount this panel? Using wellnuts? Sheet metal type screws?
The aluminum is not exactly thick on the roof and, just as important, I don't want to have any leaks. Nor, do I want the panel blowing off at 70 MPH on the road. What have others done to securely mount their panels? Do you try to ensure that you have a couple srews going into the ribs?
I intend to seal the mounts, but would like advice on what to use for the sealant. I assume Vulkem, but which one?
Thanks for the help.
Jace
JaceBeck is offline   Reply With Quote
Old 02-26-2003, 03:59 PM   #2
mtbob's Avatar
1975 31' Sovereign
Billings , Montana
I used sheet metal screws to mount our panels. I relocated panel mounts to layout on rib centerlines. The sealant was inserted between the mounting foot and the roof skin. It was provided by RV Solar. Looks like somesort of roofing tar that comes on a backing sheet and is very thin(prox 3/32") You chill it in the fridge, remove it from the backing sheet, roll it in to a small ball and then mash it with the mounting foot and screw. 1st time on the road I checked tightness at almost every stop and they never loosened. No leaks either.
mtbob
mtbob is offline   Reply With Quote
Old 02-26-2003, 04:55 PM   #3
Les Gilliam's Avatar
I did mine exactly like MTBob; but then I am from Montana too!
Les
Les Gilliam is offline   Reply With Quote
Solar Panel Installation 69Overlander Generators & Solar Power 28 03-03-2013 09:18 PM
Best Solar Panel recommendations please! westeagle Generators & Solar Power 2 11-16-2003 12:31 PM
Generator or Solar? dmac Generators & Solar Power 9 02-17-2003 10:24 AM
Help on solar panel installation Les Gilliam Generators & Solar Power 3 11-27-2002 09:28 PM
Solar battery charging Charles Q Treichel Generators & Solar Power 23 10-17-2002 11:22 AM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
