Old 11-18-2002, 05:11 PM   #1
Raptorrider2001's Avatar
Richardson , Texas
Images: 14
Question '99 25' Safari water leak driving me crazy
Brought it home from storage Sat. and doused it with water all
afternoon trying to get to leak. Started low and worked my way up
onto the top. Great! No leaks. Sun. repeated the process for 2
hours with the front end up and then down and still no leaks. Feeling
I had finally got it sealed, I returned it to the storage area and you
guessed it, night stand and beds were wet again. Aaaaaaghhhhh!!!
'99 25' Safari
2 Honda 2000i generators
'08 Chevy Duramax
'01 Yamaha Raptor ATV
'07 Yamaha Rhino ATV
2 burgler alarms: Rotweiller and Shepherd
"If you step down to get in, you have to step up to get out"
Raptorrider2001 is offline   Reply With Quote
Old 11-18-2002, 05:43 PM   #2
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
i think it was suggested before, how about pressurizing the trailer with a blower door like they use for home energy audits.
then you could go over suspect areas with a soap solution and look for bubbles.
at the least you would end up with a clean trailer.
john
Old 11-18-2002, 06:33 PM   #3
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Lightbulb that a thought~
John,
I'm surprised more ppl haven't tried that, air pressurization trick~Make sense..
When I read this, made me wonder if maybe...by some chance you're getting water collected in your belly area..When you moved it, the tilting of the unit shifted the water toward the rear??
Just a thought...
ciao
53flyingcloud is offline   Reply With Quote
Old 11-18-2002, 07:56 PM   #4
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
Re: that a thought~
Originally posted by 53FlyingCloud
John,
Just a thought...
ciao
i cannot take any credit for the idea, i read it here on another post.
but it sure seems like a good idea...
john
Old 12-06-2002, 06:34 PM   #5
Richardson , Texas
Images: 14
Thumbs up Water leak and pressurerizing
The place I store my Safari also has a shop. The owner told me he is planning on buying a unit to pressurize and check for leaks but doesn't have a time line. Don't know how long I can hold out. Can not locate anyone in the area that has one. Read somewhere that they only have about a 40% success rate with Airstreams.
'99 25' Safari
'08 Chevy Duramax
Holding Tanks on a '99 Safari 25' ElliottBartlett 1997 - 1999 Safari 11 08-01-2017 11:49 AM
Water Heater T&P 99 Bambi Leaking, need advice JimBrownUT Water Heaters, Filters & Pumps 3 01-14-2004 02:46 AM
Water leak from either hotwater heater or toilet JLD Plumbing - Systems & Fixtures 7 12-02-2003 05:37 PM
Safari 25' ss & CCD 25' - odor issues? darkStar Waste Systems, Tanks & Totes 15 09-29-2003 01:28 PM
possible plumbing leak or water leak jamesl Repairing/Replacing Floor &/or Frame 1 04-06-2003 10:52 AM
