Old 01-25-2015, 11:58 AM   #1
CHUCK
1999 25' Safari
Salinas , California
Angry 12V Actual Wiring Diagram
Streamers! I am a newbie to the Forum but a 10+ Owner of a 1999 Safari. My configuration (using towing vehicle references) is Living Room Front, Bedroom Rear, Kitchen Passenger Side and Bath on Drivers Side.
Recently, several 12 volt lights stopped working, no 12 available at sockets. Since AS in their wisdom have failed to offer a diagram showing wire routing throughout the trailer, it is very difficult to know where to start. There are no blown fuses in the DC fuse block.
Specific lights are out including the Living Room overhead, the exterior under door light as well as the bathroom. Additionally, the CO2 monitor didn't have power.
The living room wall switch, next to the door was the easiest to access and its proximity to the CO2 analyzer made it the choice for investigation, since I didn't want to start cutting into the interior "fuzzy" insulation.
I discovered there was a wire back into the insulation that looked as if it had melted open. There were burn marks on the insulation and the wire had separated. I am afraid to reconnect this cable for fear of causing more damage.
I need a diagram of the 12V system that shows wire routing so I don't have to start removing the interior of the trailer. I have search everywhere on the internet and cannot find such a diagram. HELP.
Please feel free to email me direct if you have any suggestions. Thanks
safari is offline   Reply With Quote
Old 01-25-2015, 12:35 PM   #2
Al and Missy's Avatar
2002 30' Classic S/O
Fleming Island , Florida
Here's the 2001 manual
Manuals, Airstream Travel Trailers, Touring Coaches | Airstream
They don't have one for 1999, but I doubt there is much difference.
Al
2013 Ram 2500 Laramie 4x4 Megacab Cummins
Old 01-26-2015, 12:52 PM   #3
CHUCK
1999 25' Safari
Smile Thanks to Al and Missy
I really appreciated your manual link. However, it does not address my requirement. Please refer to Page G-5 in the manual and you will see the kind of diagram I am seeking. Note this shows only the Exterior Lighting wiring routing. I need a similar drawing showing the Internal Lighting wiring routes.
If anyone can assist I will be "internally" grateful. Safari
Old 01-26-2015, 02:40 PM   #4
A W Warn's Avatar
Two Places , Sticks & Bricks
The drawing on page G-21 in the manual mentioned above should tell you everything you need regarding the 12v interior wiring. It does not show the physical location, but the color coding should tell you which wire is burned.
I feel homeless
Alan
Former Airstream Owner
(1973 31' Excella, 1978 31' Excella, 1987 32' Excella, 1999 30' Excella, 2000 25' Safari)
Old 01-27-2015, 11:22 AM   #5
1971 31' Sovereign
pickering , Ontario
wiring
Could be a lot of things but a breaker could also be at fault; try replacing the breaker that the circuit runs those lights that are out;
paulwhite is offline   Reply With Quote
Old 01-27-2015, 10:45 PM   #6
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
If you disconnect the wire from the 'fused' side of the breaker, then check if that one is to 'ground' you will 'shortly find ground'.. couldn't resist.
Peace and Blessings..
Channing
WBCCI# 30676
Old 01-27-2015, 11:32 PM   #7
Paulizor's Avatar
2010 19' International
Felton , California
Do a Google search for Airstream wiring diagram to get a hard copy if you have to have one. There are a ton of them.
Also, watch this video. It may save you some time and headache.
http://youtu.be/R2yznf5kKaI
Paulizor is offline   Reply With Quote
12v
Bambi II actual weight Antique Pedaler 1964 Bambi II 0 12-14-2010 02:14 PM
Actual Miles Dr.Theopolis Argosy Motorhomes 2 07-06-2009 09:41 AM
actual scaled weights AIR4US Towing, Tow Vehicles & Hitches 6 02-27-2008 10:04 AM
'72 Argosy 22 - 12v wiring diagram nm_mike Electrical - Systems, Generators, Batteries & Solar 1 09-27-2007 03:39 PM
Actual Length Stormy Weather 1997 - 2004 Bambi 4 08-21-2003 05:09 AM
