Old 01-21-2024, 03:47 PM   #1
2001 30' Classic S/O
Bakersfield , California
Looking for fuse
I have a 2001 AS Classic 30 with slide and the fuse for my 02 senser blew. I have no idea where the fuse is supposed to be. I even took the oven out and looked under it where the wires were leading. It is supposed to have a 1 Amp fuse somewhere in the line. Does anyone have any idea where this fuse is? I am totally baffled. DB
dbethell is offline   Reply With Quote
Old 01-21-2024, 05:46 PM   #2
Retired.
. , At Large
The only O2 sensors I am aware of are for the engines on motor homes, and those don't generally have fuses.
Are you maybe referring to a CO detector?
Old 01-21-2024, 08:03 PM   #3
CBWELL's Avatar
2010 30' Classic
Warren , Manitoba
If that is the original CO detector, it needs to be replaced!! Lifespan is only 5-7 years! Pull the old one out and check for power. Fuse will be in a place that is easy to get to, usually close to the detector.
ACI #7394
2012 GMC 2500 HD Duramax Denali
2010 Classic Limited 30' ,1994 Excella 34'
1987 Limited 34', 1976 31' Sovereign, 1976 Argosy 22' Gone to new homes
Hensley Hitch
CBWELL is offline   Reply With Quote
Old 01-21-2024, 10:14 PM   #4
Oops, wrong initials. I am referring to a CO detector. There is no fuse easily seen. I even pulled the oven to follow the wires and no fuse there either. I know it should be an inline 1 amp but I have no clue where else to look. I was replacing the old one when I noticed it had no power so I assumed it was a fuse, but where is it?
Old 01-21-2024, 11:33 PM   #5
CBWELL's Avatar
2010 30' Classic
Warren , Manitoba
If the detector is direct connected to the batteries, the fuse is possibly in the battery compartment. If you have the manual for the trailer, check the wiring schematic. If you do not have the manual, it is available on line from Airstream Inc. Go to "owners" then manuals, and it is the IC owners manual. That has all the information you need.
ACI #7394
Hensley Hitch
Old 01-27-2024, 10:02 AM   #6
Thanks to all who responded.Never did find the fuse so I am just rewiring to another hot lead and putting in a new fuse holder. It is not a hard job and should work fine.
Fuse remover, fuse set, light Vitaver Electrical - Systems, Generators, Batteries & Solar 6 09-21-2024 11:58 AM
New Owner Looking for Converter and Fuse Box Location Abj1 2005 - 2010 Safari 1 05-23-2017 02:11 PM
Looking for 2015 FB23 Fuse Plan/List FlyinNitwits Electrical - Systems, Generators, Batteries & Solar 1 11-30-2014 08:10 PM
Looking For Power Source/Fuse for Sliding Step solar-guy Sprinter and B-van Forum 1 06-22-2012 10:35 AM
looking for a 12 Volt Fuse Panel Aage Batteries, Univolts, Converters & Inverters 7 04-08-2010 04:37 PM
