Old 08-05-2024, 07:17 PM   #1
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Interior Thin-lite Lenses
I've got Thin-Lite Fluorescent lights on my 2004 Classic Slide Out. One of the lenses has cracked and is barely holding together. Looks Like the model of the fixture is a DIST-612. It's 14.937 X 5.53. I think the lens to fit is a D612.
The issue is there are no lens' being made for this fixture any more. My preference would be the lens but my guess it's a slim to zero chance. Was wondering if anyone has replaced a fixture and what did they used as a replacement. This is the fixture that you see as soon as you walk in the trailer up on the ceiling and is switched on a cabinet wall to the left as you walk in the door. There are another 3 going down to the bath entry. Anyone have a suggestion on a possible replacement that has the same or slightly larger footprint. I'd rather not have to replace all the lights along the ceiling at this point. I saw an interesting light from Miady but it's 16.5 x 6.3.
https://www.amazon.com/Miady-Interio..._source=1&th=1
It's an LED with an adjustable setting for color temperature. I tend not to use these lights much and typically use the lights over the dinette and sofa and stove hood since they are warmer and not as bright as the Thin-lites.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
Double Thin lite above lavatory quit working. Olie Lights - Interior & Exterior 1 01-05-2018 10:49 AM
Model Number for a Thin-Lite Interior Recessed Flouescent Johnsito Lights - Interior & Exterior 1 10-19-2015 03:28 PM
Thin-Lite replacement lens ghatfield Lights - Interior & Exterior 2 08-14-2007 01:29 PM
Thin Lite Install Pick Lights - Interior & Exterior 8 07-27-2003 12:45 PM
