Old 04-13-2017, 08:47 AM   #21
Riverdrifter's Avatar
2012 30' International
Ferndale , Washington
http://www.odmrv.net/tips/Jacking%20up%20Airstreams.php
This shows jacking points that are pretty far back on the trailer
Riverdrifter is offline   Reply With Quote
Old 04-13-2017, 09:57 AM   #22
PKI
PKI's Avatar
Walnut Creek , California
RD-See your point.
The floor jack in the picture does look a ways back on the frame.
One of the pictures shows a jacking point just behind the wheel, with the stabilizer not much more to the rear. Looks like a short trailer. That point is what I would expect for the recommended location. Located close to the axles so there is little to no frame flex.
The logic of not doing the rollers is that suspending the coach between the ball and the very rear of the frame places the most strain on the whole structure. Since the shell is attached to the frame, flexing of the rear section can deform the panels.
Edit - I would be reluctant to take that floor jack location as valid for anything but a frame location aid. It certainly does add confusion to the discussion.
Thanks for sharing. Pat
Old 04-13-2017, 07:33 PM   #23
Just got back from a month on the road and the rollers works just fine again going up our driveway. The wheels themselves don't lift off the ground so only part of the load is on the rollers and I go slow and try to hit the transition square. Maybe a lift kit would be a better answer but then you have 3" of more wind drag and you lift the center of gravity up some making a little less stability on the turns.
Old 04-13-2017, 07:38 PM   #24
Also Pat, if you lay on the ground under the rear of the trailer the jack point is clearly marked. Mine on the 30' unit is quite close to the rear of the trailer and Airstream says it is OK to jack one side up at that point. That puts strain on the frame longitudinally and across the trailer torsionally and yet AS says it is safe to do. Can't imagine roller wheels put as much torque and longitudinal stress on the frame if you still have the wheels on the ground.
Old 04-13-2017, 08:19 PM   #25
PKI
PKI's Avatar
RD - Understand your logic. Sounds like your 30 has a very stiff frame. Thanks for the info. Pat
Old 04-25-2017, 06:33 PM   #26
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Not designed for this, better install a lift kit....
Old 01-29-2019, 10:50 PM   #27
funguy's Avatar
2016 30' Classic
Lander , Wyoming
I installed steel micro 3" wheel casters on my 30' trailer after bending the skid bars. I'll give 'em a try and see how they work. Here's how I installed them.
https://youtu.be/rAml7zmefbY
funguy is offline   Reply With Quote
Old 08-22-2019, 10:00 PM   #28
funguy's Avatar
2016 30' Classic
Lander , Wyoming
The installation and use of these worked great - I've dragged across several low spots and the wheels stood up better than the skid bars. See my video - I installed them about 3 1/2 inches forward from rear bumper. I removed about 2 inches from the rear of the skid bars, and welded the wheels casters on the frame, same level as the removed portion of skid bar. They roll and don't bend like the skid bars did.
Old 08-22-2019, 10:06 PM   #29
dznf0g's Avatar
Oswego , Illinois
Popcorn time...I'll wait patiently.
-Rich-
Old 08-23-2019, 06:04 AM   #30
"Cloudsplitter"
....the skid plate is made to 'skid', forward within reason, rollers just stop the noise so you don't realize you are dragging 🤔
Drag wheels instead of steel drag bars under bumper? Ron cencal Bumpers & Bumper Storage 17 09-19-2020 08:32 AM
Drag & Fly :: 1988 Airstream Excella md11flyer Airstream Registry Discussions 0 04-26-2014 07:53 AM
Whada Drag HiHoAgRV On The Road... 7 11-22-2009 06:22 AM
Can you guess which rally had Airstream "drag racing?" yukionna WBCCI Rallies & Events 9 08-27-2003 08:42 PM
