Old 08-27-2019, 10:39 AM   #1
NOAZRK
NOAZRK2690's Avatar
2004 34' Classic S/O
Kutztown , Pennsylvania
Battery switch to AGM
I have two factory installed solar panels and controller with two deep cycle wet cell batteries. What, if any, controler change is needed when switching to AGM Batteries? Would damage occur if the AGM batteries were installed for several weeks without making a controller change? Is the switch to AGM batteries really longer lasting electric supply?
NOAZRK2690 is offline   Reply With Quote
Old 08-27-2019, 12:25 PM   #2
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Short answer: get rid of the stock controller, it is not good for your batteries. Look at Victron equipment. AGM's are much better than flooded and should have come with your factory solar package. You still need to take care of them, do not discharge below 50% or about 12.2v resting.
Larry
lsbrodsky is offline   Reply With Quote
Old 08-27-2019, 02:05 PM   #3
"Cloudsplitter"
We switched to two Lifeline AGM grp27's in 2007.
At the same time installed an IOTA 55a DLS IQ4. They were retired last year when we switched to Lithium batt's and Boondocker Lithium compatible converter.
The Lifelines are still doing basement duty as backup power for our sump pump.👍
ROBERT CROSS is online now   Reply With Quote
13.65? Agm Battery charging, plus battery monitoring question Mx468 Electrical - Systems, Generators, Batteries & Solar 1 05-08-2019 10:24 PM
OEM Mercedes wet battery to AGM battery Mikemdd Sprinter and B-van Forum 22 05-02-2019 06:43 AM
Battery AGM (4) 6V GC2 vs (2) AGM 8D Torpedo Family Land Yacht/Legacy Motorhomes 3 11-15-2012 06:35 PM
New Progressive Dynamics convertor, AGM battery, and Pendant questions wacnstac Batteries, Univolts, Converters & Inverters 16 05-09-2007 10:12 PM
AGM battery question LuminumTraila Batteries, Univolts, Converters & Inverters 3 03-01-2005 05:56 AM
