Old 11-02-2022, 06:44 AM   #1
jantje's Avatar
2005 30' Classic
newcastle , Ontario
Axel 2005 airstream classic
We’re can I find the ID nr from the axle from 2005 airstream classic
jantje is offline   Reply With Quote
Old 11-02-2022, 07:32 AM   #2
DaveP's Avatar
2004 28' Classic
Monument , Colorado
There should be a metal tag on the axles and it will probably show Duraflex and "Henschen" as the manufacturer. You will have to install Dexter axles as Henschen is out of business. Here is a link to my install of new axles two years ago. https://www.airforums.com/forums/f43...ic-215364.html
Here is a picture of the old tag. 4200 lb axles. I went with 4700 lb axles.
Name:	axle 061617.jpg
DaveP
2004 Airstream Classic 28 "Willard"
2023 Ram 3500 4x4
DaveP is offline   Reply With Quote
Old 11-02-2022, 07:36 AM   #3
dznf0g's Avatar
Oswego , Illinois
Not sure when the switch was made, but my 2007 had dexter axles...and the tag was a sticker. I took a pic of it back in 2010. It is illegible now. However, AS has records, by VIN, so you may be able to get the info from them.
-Rich-
Old 11-02-2022, 07:58 AM   #4
2004 22' International CCD
Beaumont , California
If you can’t find the tag, axle dealers have a series of questions concerning the dimensions and other properties about your axles, which will result in correct replacement assemblies being built for your trailer (if you answer the questions accurately).
Ndcctrucks is offline   Reply With Quote
Old 11-02-2022, 08:17 AM   #5
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
I have found the VIN tag on the trailer will list the GAWR. This is the weight rating for the axle that was installed when the trailer was manufactured. For example the tag on my trailer has a GAWR of 4000 lbs. When I replaced the axles on my older trailer I went to 4500 lb axles. Regardless a #11 Dexter axle, 5200 lb axle will be used for your trailer. It can be derated down to 4000 lbs. I bet the GAWR on your 30' trailer will be at least 4500 lbs.
2009 Dodge 2500, 6 Speed Auto, CTD, Quad Cab, Short Bed, ARE cap, Bed Rug
Propride 3P Hitch
WBCCI # 3072 Airstreaming since 2008
crispyboy is offline   Reply With Quote
Old 11-02-2022, 08:51 AM   #6
dznf0g's Avatar
Oswego , Illinois
My 2007 Classic 30' has 5000# axles, just as a point of reference.
-Rich-
Old 11-02-2022, 10:33 AM   #7
"Cloudsplitter"
As did our Classic. It came with two 3500lb axles, a GVWR of 7300lb, and a CCC rating of 680lb. NOT great.
AIRSTREAM TRAVEL UNIT, 97 Suburban 2500 Bl low mileage AS three axel ZipDee eBay Watch Airstreams on eBay 0 08-15-2013 12:30 AM
1970 Airstream Land Yacht Safari, 23 feet single axel eBay Watch Airstreams on eBay 0 08-13-2012 09:00 PM
tripple axel centinal model airstream eBay Watch Airstreams on eBay 0 02-28-2010 11:30 PM
1967 Polished Vintage Airstream Safari 22' single axel eBay Watch Airstreams on eBay 0 04-25-2009 04:40 AM
