There is a roughly 4' X 4' cover on the underside of the trailer in the far rear under the bed/bath section of my 25' Safari SS. One side has come undone and is hanging down some leaving a 2" gap at the center. I was just going to button it back up but the fiberglass insulation above it is wet. I haven't travelled recently so it is not from the road. There is no visible water or staining anywhere inside. Any ideas where the water could be from. Do you think I should just close it up and hope that fixes things?
The water in mine always has come from above. I just removed a wall panel today tracking a leak I haven't been able to identify and it was a seam lap at the first horizontal joint. The leak was in the vertical seam. I'm seasoning the Vulcum for the next test. I'm sure I got it thought because I just followed wet insulation up from the wet floor. There was a small mold spot where the leak has been entering.
Click on the link to see a picture of the Sioux River falls near my home. https://visitsiouxfalls.com/assets/i...uxfalls-og.jpg
hmm, so you think the fiberglass is wet because the water is spraying UP from the ground? :P
i know..and i think you know...investigating is going to open a whole can of worms. but i know, and YOU know... you gotta do it!! because its only gonna get worse.
split rock - what does " seasoning the Vulcum" mean?
