RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 06-13-2011, 11:07 AM   #1
DJW
DJW's Avatar
2004 25' Safari
Lafayette , California
'04 Safari- what does the external cable connection energize?
Sorry, I'm sure this has been asked before, but couldn't find in a search.
I'm trying, for the first time, to connect a RV park cable to my AS. I've connected it to the external box (next to the phone input at rear of trailer), but can't get a signal inside. There is are 2 unlabled internal jacks coupled with a cig lighter (bedroom and front under TV cabinet), and a 2 jack unit saying "Satelite in and Satelite out". Where oh where do I connect? And, if I'm ever someplace where there is broadcast TV, which of these is connected to my roof top antenna?
Thank you from beautiful Ft. Bragg, CA!
Don
DJW is offline   Reply With Quote
Old 06-13-2011, 01:23 PM   #2
timmaah's Avatar
1999 25' Safari
On , the road
I believe you need a jumper for those 2 Sat in/out connections.
The "Satellite in" is the live feed from where you connected the cable line. The "Satellite out" are the connections to the 2 TV locations. Take a short piece of coax and connect the Sat in/out and you will get cable to the TV locations.
It is laid out like this so you can connect a dish via the outdoor coax connection and place the satellite box where the Sat in/out connections are, thus sending a signal to both TV's
timmaah is offline   Reply With Quote
Old 06-13-2011, 01:55 PM   #3
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
The "cigarette lighter" is a 12 v. socket. It may be for a 12 v. TV. The unlabeled jacks should be coaxial cable connections—one for the roof antenna and the other for the cable connection outside. You can get 3 short pieces of coaxial cable and a splitter to combine for the TV coaxial input; otherwise you have to keep switching which cable inputs to the TV. The TV should allow you to select "air" or "cable" by a menu and you then can program it for wherever you are.
One some models there will also be connections for sound from the TV to go through the receiver (radio, DVD, CD) and use the sound system.
You also need the jumper. It sounds like you bought this trailer recently and I suspect the previous owner had a satellite system and didn't replace the jumper. So you need a 4th short piece of coax.
Gene
Old 06-13-2011, 01:59 PM   #4
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
If it's all original equipment, the coax jack by the 12v receptacle (cigarette lighter-looking) is for the antenna on top of your rig... When you are using the air waves and your roof-top antenna, that is where your TV is connected. There should be a little button near that jack...that is the "booster" and it needs to be pushed in (lit) to get a good signal. Note that if your TV is not digital-ready you will need a converter box to receive the digital signal. (If it's a 2004 and it's the original TV, it most likely is NOT digital-ready...we needed one for our 2006 with a Sony.)
When you switch to cable (or satellite), disconnect the cable going to your TV from the antenna input jack and move it to the coax connection labeled Satellite In. That gives your TV access to the incoming cable (or satellite) connection. Depending on what kind of TV you have, you may have to reset your TV to recognize a cable signal in the TV's set-up menu. You don't have to worry about the digital box stuff if you are on a cable signal.
TB & Greg and Abbey Schnauzer
AirForums #21900 . Membership Chair & PastPrez, 4CU/WBCCI
#3954
Old 06-13-2011, 03:08 PM   #5
Master of Universe
Gene's Avatar
In ours the cable connection works badly when the antenna booster is on. It draws power from the batteries when it is on and will increase battery drain. So get in the habit of turning it off—it saves batteries and when you use the cable connection you may wonder why the signal is so bad.
Gene
Old 06-13-2011, 03:23 PM   #6
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
We also turn off the booster when it's not being used...especially at night ... it puts out a lot of light in our bed area for no bigger than it is..
#3954
2010-2011 Aux/MP3 cable connection gmillerok1 Sprinter and B-van Forum 8 09-25-2011 03:45 PM
'04 Safari- what does the external cable connection energize? DJW Audio, Video & TV 0 06-02-2011 09:35 AM
Another Newb Question-Power Cable? jambie 2005 and newer - Bambi all models 1 03-08-2011 10:24 AM
Int'l Bambi 19' External Propane Connection? jambie 2005 and newer - Bambi all models 1 03-06-2011 08:28 PM
