Old 09-07-2018, 04:16 PM   #1
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
Wired sewer hose reel problem
Yesterday after dumping my tanks the hose reel stopped working. Did a quick check of the fuse panel and all looked ok. I stuffed the extended hose into compartment - it just fit. Later in day I had more time to look closer at the fuse panel. Turned out the 15A fuse for the hose reel was just loose - it wiggled in the socket.
It must have worked loose on some of the rough gravel and logging roads I was recently on driving up to my brothers cabin in northern Minnesota.
Lesson learned - check the fuse panel for loose fuses causing intermittent 12V electrical problems.
- - Mike
Old 09-07-2018, 06:58 PM   #2
Air99's Avatar
2014 Interstate Ext. Coach
Camas , Washington
glad you found it!
Air99 is offline   Reply With Quote
Sewer solution to home sewer-so difficult? lsbrodsky Plumbing - Systems & Fixtures 39 05-05-2018 09:35 PM
Attention New to Airstream owners - sewer line outlet info - Thetford sewer systems Catman6 Waste Systems, Tanks & Totes 29 04-01-2011 05:22 PM
Staining Sewer vent from sewer gas TheProfessor Cleaning, Stripping & Polishing 6 02-16-2008 01:42 PM
Fred vs. Hose Reel ViewRVs Airstream Motorhome Forums 10 09-01-2007 07:34 PM
Automatic electric cord reel cameomike Batteries, Univolts, Converters & Inverters 5 09-02-2002 12:04 AM
