Originally Posted by k9jackie
Is it a good idea to leave the interstate plugged in during the winter? In the past I stored it outdoors without being hooked up but now I have a good spot next to my garage where I can... will it matter either way?
You will want to get the (optional) battery temperature probe for the Magnum inverter/charger if you don't already have it, so that the charge rate will be temperature-compensated. But with that probe in place, you can leave the van plugged in 24/7 all winter long with no ill effects.
