Old 05-26-2018, 01:05 PM   #1
rowiebowie's Avatar
2012 Avenue Coach
Corpus Christi , Texas
Which Adhesive to Re-attach Tank Heater Pad?
The leading edge of my gray tank heating pad partially detached on the final leg of our trip home. It's hanging approximately half off (just enough to rest on my driveway). Looks like the original attachment was a "peel-&-stick" method.
The front edge looks good, so it didn't drag on the roadway. But it probably bent completely backward (flapping in the wind) so I can only hope the wiring is ok.
Anyway, I need to re-attach so any suggestions are appreciated.
rowiebowie is offline   Reply With Quote
Old 05-26-2018, 01:12 PM   #2
Kwils25's Avatar
2014 Interstate Ext. Coach
Taylor Ridge , Illinois
I used contact cement. Itís held up nicely for three years.
Kwils25 is offline   Reply With Quote
Old 05-26-2018, 01:44 PM   #3
J&J In A Can
J&J In A Can's Avatar
Cottonwood , Arizona
I cleaned the surfaces with denatured alcohol and then used contact cement.
2016 Interstate GT Twin
J&J In A Can is offline   Reply With Quote
Old 05-26-2018, 01:49 PM   #4
rowiebowie's Avatar
2012 Avenue Coach
Thanks. Did you have to take the old adhesive off, and if so, what did you use?
Old 05-26-2018, 01:54 PM   #5
iaqstuff's Avatar
2013 Interstate Coach
Yarnell , Arizona
I'd just use that ol' yellow automotive contact cement.
iaqstuff is offline   Reply With Quote
Old 05-26-2018, 02:37 PM   #6
2018 Tommy Bahama Interstate
Huntington Beach , CA
You can use 3M spray glue found at hardware stores. Good stuff.
https://images-na.ssl-images-amazon....X342_QL70_.jpg
https://www.amazon.com/3M-77-Multipu...70_&dpSrc=srch
Boom23 is offline   Reply With Quote
Old 05-26-2018, 03:21 PM   #7
Raymond , Iowa
I cleaned with solvent then used liquid nails and held it for a few hours with a piece or wood jammed against it. Has worked fine for a year and thousands of miles.
Titus is offline   Reply With Quote
Old 05-26-2018, 04:51 PM   #8
Prof. of Pending Projects
wachuko's Avatar
Orlando , Florida
3M spray adhesive and then I used black duct tape around it... sucker is not coming off again!!
Safe travels!
Wachuko
WBCCI #26769
2018 Airstream Interstate 3500 Lounge EXT Tommy Bahama w/ARS
wachuko is offline   Reply With Quote
Old 05-26-2018, 04:59 PM   #9
rowiebowie's Avatar
2012 Avenue Coach
Yes, I thought about using Gorilla Tape around the perimeter after reattaching just to keep the edges secure.
Thanks for all the suggestions.
Old 05-27-2018, 10:09 AM   #10
Abbeville , Georgia
Heating Pad Adhesive
In Alaska, we used the high-temperature RTV silicone adhesive for pad heaters on oil pans and transmissions. (Red color) It is available in automotive supply stores. Self-adhesive aluminum tape was placed over the pad to protect the heater from road debris/salt etc. Just be sure to clean the surface thoroughly before applying the adhesive.
My heaters are still firmly on and functional after ten years and 100K+ miles.
Good luck!
AlaskArt is offline   Reply With Quote
Old 05-27-2018, 10:20 AM   #11
Wannabe RV'er in training
Alex AVI's Avatar
2018 Interstate Lounge Ext
High Desert , Las Vegas , Nevada
+1 even though have not used yet on my AI pad heaters, but I have used on plenty enough areas in the underbelly of my other vehicles (mostly oil pans and trans), that I can definitely say they work.
Alex AVI is online now   Reply With Quote
Old 05-27-2018, 11:12 AM   #12
eubank's Avatar
Airstream - Other
Bosque Farms , New Mexico
I'd also recommend 3M Weatherstripping Adhesive (sometimes called "monkey snot").
Clean the surfaces well. Follow the instructions.
Lynn
WBCCI 21043
Old 05-27-2018, 12:19 PM   #13
mykytiukr's Avatar
1965 24' Tradewind
almena , Wisconsin
Rtv
Good luck!
I strongly agree with this guy!!! I worked with heavy trucks in Alaska for years and this was always the best way to attach something like that. Take a can of Brake Clean to clean the surfaces and apply the RTV generously. Make sure to let it cure for at least twelve hours before driving. A day would be even better. Itís not going to fall off!!!! Motor On!!!!
mykytiukr is offline   Reply With Quote
Old 05-27-2018, 12:35 PM   #14
2014 30' International
DFW Airport , Texas
Originally Posted by Boom23 View Post
+1, works well
Vlamgat is offline   Reply With Quote
Which adhesive to use on septic connections general78 Plumbing - Systems & Fixtures 0 04-02-2015 11:39 PM
Adhesive to bond polyethylene flange to fiberglass tank Jammer Waste Systems, Tanks & Totes 6 01-28-2013 05:54 AM
How do you attach the fitting to the black tank? drowe42 Waste Systems, Tanks & Totes 10 07-12-2010 01:07 PM
Insulation in the walls -- adhesive or no adhesive? wrajr Repairing/Replacing Floor &/or Frame 8 04-27-2010 09:08 PM
Which flooring adhesive? Anniedog Floor Finishes 1 09-18-2009 05:23 AM
