05-15-2020, 02:24 PM
2016 Interstate Lounge Ext
Pittsburgh
, Pennsylvania
Where are battery jumping posts
I have a 2020 Interstate Lounge EXT on a Mercedes 3500 chassis. I had previously a 2016 model. I can find the positive post in the engine compartment but cannot find a negative post. I can’t believe they would expect someone to randomly attach to a part of the engine or chassis to ground. I called Mercedes Corporate and they were of no help. My dealer is a far distance away and unavailable to call. Would appreciate some help. Thanks
05-15-2020, 03:23 PM
Contributing Member
Austin (Hays County)
Use any substantial metal piece in the engine compartment for the ground. Always hook up the ground last and remove it first.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
05-15-2020, 03:56 PM
Sag Harbor
, New York
What does your owner's manual say about jump-starting the vehicle?
For our Ford Transit van, we do what John just said FWIW. Pretty sure the owner's manual is fairly clear about this.
Peter
05-15-2020, 04:07 PM
Pittsburgh
, Pennsylvania
Not looking to jump start vehicle but connect a portable air compressor for power. On my 2017 there was a negative post. There must be one on my new unit just can’t find it
05-15-2020, 04:10 PM
Sag Harbor
, New York
The Mercedes manual [not AS] should refer to the negative post issue in a discussion of jump starting the vehicle.
Please check that Mercedes manual without over-thinking this IMO. A lot of newer vehicles do not have a negative post per se.
Peter
PS -- FWIW a 2017 video . . . guessing that your 2020 negative connection is more subtle than this IMO:
05-15-2020, 04:44 PM
Pittsburgh
, Pennsylvania
I checked the manual and even called Mercedes corporate in Georgia. They could not find it in manual and told me to go to the service department of a dealer. I am going to look around the engine compartment some more. Must be there
05-15-2020, 07:14 PM
Sag Harbor
, New York
Thanks for the update. So you don't have that brass fitting sticking out for the negative shown in that YouTube video?
Here is another but for a 2016. Shocking that Mercedes could not help you IMO! We hook up our 12-volt compressor the same way John said in his earlier post, clipping the negative to the nearest substantial metalwork.
If the compressor runs, that is your "full scale model" confirmation IMO.
Good luck,
Peter
05-15-2020, 08:52 PM
2024 Interstate 19
Fulton
, Maryland
Yes it should be there in same spot on driver side of engine compartment. I found the linked YouTube video that shows the engine compartment details at 13:30. Also in the attached image from this video you can see the brass ground stud on the driver side that I circled in red.
https://youtu.be/qYkWqVR9iGk
If you happen to have the optional Auxiliary battery in the engine compartment in this location it may obstruct the ground stud. If you do have the auxiliary battery just connect to the negative terminal as the van batteries have a common ground.
Hope this helps,
- - Mike
2024 Airstream Interstate 19e AWD
Previous: 2013 Airstream Interstate 3500 Ext Lounge
05-15-2020, 08:57 PM
Pittsburgh
, Pennsylvania
Thanks OTRA15 for you Tube video. I found brass fitting in the far drivers side of the engine compartment. It was not in plain site nor marked to indicate it was a negative post. The video showed me what to look for. Thanks again
05-15-2020, 09:21 PM
2024 Interstate 19
Fulton
, Maryland
Glad you found it. That video and image I posted above was a 4-cylinder gas engine Sprinter so it didn't look right. Found a 2019 V-6 diesel engine compartment video (at 1:27) and image that also shows the brass ground stud in same location; that I annotated by yellow arrow. They have never been marked.
https://youtu.be/vqqkad9I3tw
- - Mike
05-16-2020, 05:21 AM
Sag Harbor
, New York
Glad you found it. It might be instructive to look at the Mercedes Sprinter manual again, now that you do know where the negative post is, to see if the manual refers to it in any way, however obliquely. There should be some reference to it, in the section on jump-starting due to a dead battery, even if the language is poorly written or inaccurate.
Worth a final check, as a re-assessment of the thinking process here IMO.
As we say in the construction trades, "measure twice, cut once . . . "
Happy trails!
Peter
05-16-2020, 12:10 PM
1989 Excella 32 footer.
1989 32' Excella
Check
, Floyd County, Virginia
Basic electricity is, you have to have a ground or negative and a positive terminal. Also since the battery is grounded to both the frame (most of the time) and the engine you just have to put your ground terminal of the compressor to any heavy metal. It'll work as radio tech do it all of the time to mount radios in police, fire, rescue, and ham radio buffs to boot. Or at least they should be.
Good luck with your project, ours are at a stand still for now.
73
Russ
Russ Abbey
Floyd County Virginia
N4MAV - FCC Call sign for Ham Radio
05-17-2020, 10:58 AM
2021 30' Flying Cloud
Airstream - Other
Airstream - Other
Lady Lake
Good Advise
Always a safe practice and with a computer controlled vehicle mandatory. Make and break on the negative side not positive. Why? Induction damage to sensitive electronics and the change of blowing off the airbags!
