03-19-2021, 02:18 PM
2017 Interstate Grand Tour Ext
Loudon
, Tennessee
When to Plug in ??
We have a 2017 AS Interstate and are newbys
Our AS is in covered storage with all the power turned off. We have it plugged in but I am wondering if we should be plugged in all the time? Would that have any effect on battery life over time?
03-19-2021, 02:33 PM
2015 Interstate Ext. Coach
Columbus
, Ohio
We keep our 15 lounge plugged in whenever it’s not in use & has not hurt our batteries!
Our year charges the batteries with the switches in the off position.
Am not sure it that’s true for your 17 as well!
Adventure before Dementia!
03-19-2021, 03:23 PM
Living Riveted since 2013
2016 Interstate Lounge Ext
Green Cove Springs
In my experience, the best way to keep your coach and chassis batteries happy in storage is to keep the coach plugged in and the chassis battery connected to a battery tender. We pay a small monthly premium at our storage location so we can use an outlet there for this purpose. Check your coach to see whether it has to be in "Use" position for it to charge the batteries. That seems to vary by model year and, possibly, by configuration as well. I know some like to disconnect the chassis (engine) battery while in storage, but doing that cuts off power to the radio memory, which means I'd have to program it all over again when I reconnect...so, I don't do that. Instead, I use a battery tender.
03-19-2021, 05:38 PM
Western
, Tennessee
On my 2017, I kept plugged in at all times with battery switch off, will charge the batteries for the Airstream part. This method did not charge my "start the MB engine" battery. I connected a "Battery Tender" to the start battery, plugged this into the "coffee" plug as it is live anytime plugged in to shore power. The "coffee" plug is the one over the stovetop.
As was said earlier, this varies by year and versions within a year. Don't trust the manual on this. Need to check voltage in MB battery and AS batteries, until you can determine the correct method for your AS.
03-19-2021, 05:55 PM
2021 Interstate 19
Seattle
Perhaps a different strategy for the newer Lithium models with the Battleborn batteries. This video with BAttleborn would suggest getting the house batteries to a full charge and then have them sit disconnected up to a year.
03-19-2021, 06:06 PM
Tampa
2017 was the last year of the single stage converter. So, No, don't leave it plugged in.
My work around is to purchase a trickle charger, I like the NoCo Genius 3500, which has a "float" setting, so once the batteries are charged, it stops charging. Plug that in and don't plug the trailer in. The NoCo Genius 3500 comes with a harness to permanently attach across the batteries so you just snap the cables together.
Note: many like Deltran "Battery Tender" trickle chargers. I've had six of them on motorcycles and over time all failed.
03-19-2021, 06:35 PM
Sag Harbor
, New York
Are you sure this is true for the OP's 2017 Airstream Interstate motorhome?
03-19-2021, 07:03 PM
Green Cove Springs
Excellent point re: Lithium coach batteries. If you can be confident that you've killed all phantom drains on your lithium coach batteries, you can skip plugging in the coach because they will be fine when you come back. We did that every winter with our travel trailer. We'd charge the batteries, disconnect from all drains and power, and when we picked the trailer up several months later, the batteries were still at 100%. Finding and eliminating phantom drains can be a little trickier in an Interstate unless you have a BRS (Big Red Switch) that physically disconnects those batteries from the coach.
Given the chassis battery is conventional, I would still recommend a battery tender for that one.
03-19-2021, 07:48 PM
Tampa
My bad.
I saw 2017 and that's the year of my FC.
I apologize.
03-19-2021, 08:44 PM
Castle Rock
This is not true for an interstate.
