Old 02-22-2024, 06:49 AM   #1
2022 20' Caravel
2019 Interstate Lounge Ext
Noblesville , Indiana
When Airstream's specs are wrong!
When Airstream's specs are wrong on the overall height of the AI19 AWD after they change the AC unit and forget to update the spec. Luckily, I have a saw. The actual height is 9'10 1/2", Not 9'9"
vanderwielen is offline   Reply With Quote
Old 02-22-2024, 07:16 AM   #2
Oak Park , Illinois
Totally agree...here is their out listed on every brochure they release, which really puts the onus on the dealer to communicate to the would be customer, more or less- of course assuming the factory let the dealers know....
Product information, specifications, and photography in this brochure were as accurate as possible at time of printing. Photographs may contain some features that are optional on your vehicle.
Since we continually strive to improve our products, actual products may differ. Prices and specifications are subject to change without notice. All capacities are approximate and dimensions are nominal. Some features or options may be different or unavailable in other countries.
Warning – This information is intended as a guide only. Weights of individual vehicles may vary. Consult your owner’s manual for complete loading, weighing, and towing instructions. Do not overload the travel trailer.
sfranklin is offline   Reply With Quote
Old 02-22-2024, 07:21 AM   #3
Oak Park , Illinois
....of course they also say this in some of their literature too:
Water check ensures the shell is watertight
Name:	Screen Shot 2024-02-22 at 8.22.31 AM.jpg
Old 02-22-2024, 07:42 AM   #4
Rig Rat's Avatar
2015 Interstate Ext. Coach
Columbus , Ohio
Attachment 441278
I bet you're glad that you had a dealer drive one over to check the clearance before you ordered/bought one!
Adventure before Dementia!
Rig Rat is offline   Reply With Quote
Old 02-22-2024, 09:06 AM   #5
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
Tire pressure changes with temperature. Springs sag / rise a bit with loading. The angle you go into the garage may or may not be "dead flat". There are lots of variables. All of them get into the mix in terms of clearance.
Simple answer: You want a lot more "air space" than an inch or two ....
Old 02-22-2024, 11:07 AM   #6
2021 Interstate 24GT
Magnolia , Texas
Attachment 441278
I can definitely empathize! My short term and longer term solution below. (granted, I knew clearance was going to be a problem from the start)
WeekendBob is offline   Reply With Quote
Old 02-22-2024, 11:28 AM   #7
2018 30' Flying Cloud
Springfield , Ohio
I don't see any major problems with the above posts, but be cautious if you're considering cutting into a door header. You could have a catastrophe sometime in the future.
2018 Flying Cloud 30RB + 2020 Silverado 2500HD Duramax/Allison
tbrowne is offline   Reply With Quote
Old 02-22-2024, 02:58 PM   #8
PC Conner's Avatar
2018 27' Flying Cloud
INDIAN HARBOUR BEACH , Florida
Attachment 441291
Attachment 441288
Very elegant. I like the top pic.
Of course, the OP didn't say if he was going to cut the garage door larger or the AS shorter!
PC Conner is offline   Reply With Quote
Old 02-22-2024, 04:17 PM   #9
1988 32' Excella
Robbinsville , New Jersey
While the OP didn't say, he did post a picture of himself (well someone) cutting the door opening higher.
Old 02-23-2024, 08:19 AM   #10
2022 20' Caravel
BTW, there is a backup plan. A new AC unit. Advanced RV out of Cleveland and do a low profile retrofit. the BAM BAM YouTube channel also did one. I'd like to find out why AS changed their AC to this unit.
Old 02-23-2024, 10:33 AM   #11
Traverse City , Michigan
On my 2016 GT the new Houghton only dropped 1 in overall height after installing the DIY Van cnc plate (it is about 1 thick). Not sure if ARV uses the cnc plate.
Heckler56 is offline   Reply With Quote
Old 02-23-2024, 10:34 AM   #12
FYI, Vandy is an engineer.
Old 02-23-2024, 12:00 PM   #13
Oak Park , Illinois
Attachment 441291
Attachment 441288
Very nicely done! Amazing how much dead space that arch consumed!
Old 02-23-2024, 02:32 PM   #14
Boxster1971's Avatar
2024 Interstate 19
Fulton , Maryland
More than likely Airstream switched to installing Coleman-Mach air conditioners because they are both Thor owned companies.
https://www.thorindustries.com/thor-companies
- - Mike
2024 Airstream Interstate 19e AWD
Previous: 2013 Airstream Interstate 3500 Ext Lounge
Cabinet specs - any specs out there KariRich Cabinets, Counter Tops & Furnishings 0 02-23-2016 11:58 AM
Refrigerator thermostat readout - wrong wrong wrong BoldAdventure Refrigerators 12 09-18-2015 05:02 PM
Buck rivets look wrong?using wrong air hammer bit? shadeemry Ribs, Skins & Rivets 11 06-07-2014 07:42 PM
HELP with Brakes- Wrong TV? Wrong AS? Flying Gypsies Brakes & Brake Controllers 7 07-24-2011 07:04 AM
'71 Airstream Caravel 18' weight specs PeterH-350LE 1969-1971 Caravel 0 06-15-2002 06:28 AM
