Old 09-11-2019, 12:17 PM   #21
2018 Interstate Lounge Ext
LV , Nevada
Originally Posted by Alumaholic View Post
Well, is it better than gravity or not?
ALUMAHOLIC - I assume since OP said "worked like a charm" it meant better ? Coz I hear folks describe gravity dumping as a simple process that works, but never described it as a "charm"
Alex AVI is offline   Reply With Quote
Old 09-11-2019, 01:33 PM   #22
Just an old timer...
85MH325's Avatar
2022 27' Globetrotter
1998 19' "B" Van Airstream 190
Tipton , Iowa
Images: 37
In the ensuing twenty-one years since 1998, I've had 13 motorhomes/trailers with black tanks with manual gravity dump systems. I've never had one fail to dump or to empty fully, and I had to replace one manual dump valve because the housing broke; likely from something smacking it.
KISS. Comparing those twenty-one years' experience just with the experiences of the past year or two with members here with macerator pump systems, I don't know how much more "charmed" you can ask of a sewage dump system.
Quite frankly, my '04 AI has a gravity, solenoid-actuated dump valve that still works, but I'm quite sure EVERY time I dump it that the last time was it's last. So far, so good though.
"fixin' my broken Airstreams since 1987..."
ACI 3655 AIR 2053 Current:2022 Globetrotter 27FBQ & 1998 B-190
Airstreams Emeritus:
'53 Flying Cloud, '57 Overlander, '61 Bambi, '70 Safari Special, '78 Argosy Minuet, '85 325 Moho, '94 Limited 34' 2 DR, '94 B190, '04 Interstate T1N, '20 GT23 FBQ
Refrigerator thermostat readout - wrong wrong wrong BoldAdventure Refrigerators 12 09-18-2015 05:02 PM
Buck rivets look wrong?using wrong air hammer bit? shadeemry Ribs, Skins & Rivets 11 06-07-2014 07:42 PM
HELP with Brakes- Wrong TV? Wrong AS? Flying Gypsies Brakes & Brake Controllers 7 07-24-2011 07:04 AM
gravity fed from a ram pump cnsilver Fresh Water Systems 5 09-11-2008 06:27 PM
Measuring specific gravity of battery electrolyte guy99 Batteries, Univolts, Converters & Inverters 6 01-20-2008 07:31 AM
