Old 08-27-2018, 12:00 AM   #21
OAKDALE , California
Thanks!
Thanks everyone! We followed the suggestions this morning for purging with everything open inside.... and it worked! Yea!!!!
jldejong is offline   Reply With Quote
Old 08-27-2018, 03:15 AM   #22
Long Island , New York
Great! Thanks for the update.
Be sure to use a new[ish] potable water hose and filter like the Camco when you fill the tank, and also when you hook up to city water.
Happy Trails!
Peter
https://www.amazon.com/Camco-25ft-Ta...TDY7FQK66143X3
https://www.amazon.com/Camco-TastePU...v+water+filter
Old 08-27-2018, 04:26 PM   #23
rowiebowie's Avatar
2012 Avenue Coach
Corpus Christi , Texas
Congratulations! My system holds pressure for weeks so long as I'm parked. Driving creates "air pockets?" and lots of air in system. I just replaced some "shark bite" connections in case they were causing the problem. I hope my fix works and your system problems stay solved. But a little air purging is not a big deal, so don't worry if it's needed now and again.
rowiebowie is offline   Reply With Quote
Pump doesn't turn off and it doesn't pump water either. I don't know what to do! Melimelo Fresh Water Systems 10 05-25-2018 01:39 PM
Hooked up water in winter and can't get water pump to pump water mrpettit Water Heaters, Filters & Pumps 8 05-06-2015 06:46 PM
Pump in RV Antifreeze Downstream from the Water Pump? KJRitchie Winterizing, Storage, Carports & Covers 6 01-09-2015 01:18 PM
air pump vs water pump kamo Water Heaters, Filters & Pumps 22 02-27-2008 02:01 PM
68 water pump-should the pump cycle? Boondocker Water Heaters, Filters & Pumps 8 08-06-2006 10:11 AM
