Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Sprinter and B-van Forum
Old 10-19-2014, 07:18 PM   #1
FunWaggin's Avatar
2016 Interstate Lounge Ext
Raleigh , North Carolina
Water pressure regulator
We are proud new owners of a 2014.5 AI. I am wondering if the AI has a built in water pressure regulator? I recall the sales guy mentioning it but I want to be sure I understood correctly.
FunWaggin is offline   Reply With Quote
Old 10-19-2014, 07:25 PM   #2
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
It is built into the external city water receptacle where you hook up. I think the receptacle says it is a pressure regulator there on the outside.
Doug and Cheryl
Old 10-19-2014, 07:27 PM   #3
FunWaggin's Avatar
Thank you for the rapid reply. We are heading out tomorrow and feel better knowing that.
Old 10-19-2014, 07:34 PM   #4
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
I started to use one now in addition to the one in the AS as I believe (although not totally sure) that high water pressure damaged one of my water hoses
PharmGeek is offline   Reply With Quote
Old 10-19-2014, 07:59 PM   #5
dkottum's Avatar
Pharm, your water hoses are outside the trailer and not protected by the built-in unit. There is a good chance your hose damage occurred from expansion within the hose from heating of the sun, so a pressure regulator at the campground spigot would not have protected that either. There is really no reason to use an additional pressure regulator.
Doug and Cheryl
Old 10-20-2014, 06:00 PM   #6
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Ohhhh - I failed to consider that - I guess in hot weather if off and about can turn off and unscrew ?
I don't see why high pressure from the spigot could not damage the water hose (probably a dense moment)
Old 10-21-2014, 07:34 AM   #7
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Physics: Water only expands by 1.25% when heated by 100 degrees, as long as you don't heat it enough to boil it. That's not enough to rupture a hose, not even a hose that has been softened by direct exposure to the sun.
It has to be the pressure in the hose, especially when you're not using any water so all of the faucets inside are closed and the pressure has nowhere to go. It's force of habit to open the spigot at the service pedestal all the way every time you hook up, but if municipal water pressure is unusually high, you can just open the spigot partway and thereby reduce the pressure in the hose.
Old 10-21-2014, 07:39 AM   #8
King of the Zebra Speedo
Panama Red's Avatar
Obrien , Florida
You'll only reduce the amount of flow by not opening the spigot all the way. With everything in your camper turned off, the pressure will build to whatever the supply pressure is, even if you barely crack open the spigot. In electrical terms, it's like voltage and current. You still have the same amount of force pushing it (voltage) just not as much flowing through it (current). To reduce the pressure on the hose, you have to put the regulator on the output of the spigot...
-Red
Somebody ought to clean these windows. There is a tremendous buildup of gook all over them...
Panama Red is offline   Reply With Quote
Old 10-21-2014, 07:42 AM   #9
You're right. Just goes to show that it's a good thing I'm retiring at the end of the year if I keep having senior moments like that.
Old 10-21-2014, 07:44 AM   #10
Panama Red's Avatar
Obrien , Florida
Lucky dog! I'll take those senior moments if it means I get to retire... Just under four years now.
-Red, getting short-timers a little early...
Old 10-21-2014, 07:49 AM   #11
dkottum's Avatar
I've had a hose expand a permanent balloon at home lying in the hot sun when the supply spigot on the house was off and the spray nozzle was also off trapping whatever city pressure was there, then softening and adding the thermal expansion of the sun.
It was a cheap hose, like the ones rv's use. I don't know what else could have caused it.
Doug and Cheryl
Old 10-21-2014, 07:52 AM   #12
dkottum's Avatar
Protagonist. By the way, congratulations on your upcoming and soon-to-be retirement! Senior moments only mean life is less stressful, it's wonderful.
Doug and Cheryl
Old 10-21-2014, 08:14 AM   #13
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Even though the Airstream has an internal water pressure regulator, I still use an external one attached to the water supply spigot at the campground. I am probably being overcautious but it just makes me feel better.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
Old 10-21-2014, 09:25 AM   #14
dkottum's Avatar
Brian, I used a second one for awhile too, then asked myself why. With no good answer I got rid of it.
Doug and Cheryl
Old 10-21-2014, 10:29 AM   #15
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Are we sure that the Interstates have the built-in regulator?
2011 Interstate SOLD! Upfitted 2017 Transit 350. SOLD!
Old 10-21-2014, 10:55 AM   #16
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
The 2014 Interstate Parts PDF, which I downloaded from the Airstream website, does mention a "City water fill w/regulator, chrome".
Old 10-21-2014, 11:01 AM   #17
Home of Vortex tuning
CDONA's Avatar
2013 27' FB Eddie Bauer
Spearfish , South Dakota
My first time on my Alfa, I ran an external pressure reducer into external water filter into the built in PR, and lived with weak flow from the shower.
Once I realized there were two inline PR's, I pulled one and got more than the dribble. The water pump had better shower flow.
My new EB the water inlet/PR started leaking back in Jan. I pulled it from the skin, tightened it (4 screws on two piece plastic construction) and then left it loose to dry out for a couple of weeks. It started leaking again this month, so I replaced it on my dime, cheaper than a trip to Tucson for warranty.
I'm keeping the old one to seal up with silicone as backup.
"Chip Tank" is in Westwood Ca.
CDONA is offline   Reply With Quote
Old 10-21-2014, 04:35 PM   #18
Newbie
joemikeb's Avatar
2013 Interstate Coach
Fort Worth , Texas
My 2013 came with an external pressure regulator in a plastic bag along with some other small items such as the hose and nozzle for the external shower. I use it and have no low water pressure problems.
Make errors — otherwise the Great Spirit realizes
you have finished your purpose on earth.
— Navajo saying
joemikeb is offline   Reply With Quote
Old 10-21-2014, 04:38 PM   #19
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
I use external as well and water pressure is un affected as far as I could tell
Never bad a problem with water pressure yet
I still am not clear why high pressure at spigot could not damage a water hose
Old 10-21-2014, 06:18 PM   #20
dkottum's Avatar
This is from your (2014) Interstate Owners Manual:
"Your plumbing system has a built in pressure regulator to protect your lines and faucets from extremely high pressures on some city water systems. An after-market external regulator is not recommended, as it could lower the water pressure at the inlet and thus to your faucets and shower."
Doug and Cheryl
Water pressure regulator? yukionna Fresh Water Systems 7 06-16-2010 10:03 PM
Help!! Need access water pressure regulator Crawdad Fresh Water Systems 5 07-15-2007 02:16 PM
Water pressure regulator...from factory? Kistler Our Community 6 07-14-2007 09:29 PM
Water Pressure Regulator & External Water Filter safarijim Off Topic Forum 7 02-01-2007 08:17 PM
Any PLUMBERS out there?? Pressure regulator, water pump questions SmokelessJoe Water Heaters, Filters & Pumps 65 01-11-2007 03:01 PM
