Old 12-11-2021, 02:58 PM   #1
Mt Hamilton , California
Water Leak in 2014 Interstate - HELP ?!
Hi, I am seeing what looks like fresh water leaking out into the alley way (walk way) just underneath the wall to the shower/toilet. There is a flat panel in the alley way covering what looks like the side of the step up for the toilet. Or said another way, inside the wet toilet the toilet bowl sits up on a step above floor height - outside the toilet, across from the kitchen area there is a wall panel thats about 6-8 inches tall that looks like it is covering the space underneath the toilet step. Clean water is leaking from under this panel and from underneath the wall between that panel and the shower door.
Any ideas on where this water is coming from?? We have been plagued with water leaks since getting the Airstream 9 months ago.
Brian
scotsman1 is offline   Reply With Quote
Old 12-11-2021, 03:45 PM   #2
2017 23' International
Bend , Oregon
Look at you mixer valve (shower control). I had a similar issue where the cold water connection to the mixer was (what appeared to be) installed incorrectly was leaking. I removed the valve and all the connections and replaced the end fitting on the cold water line (standard fitting available to any home center.
Airstream692 is offline   Reply With Quote
Old 12-11-2021, 04:39 PM   #3
Yessss!!
Woohoo, thanks thanks thanks. I took the access panel off and it is the cold water connection that is leaking !!
Brian
Old 12-11-2021, 11:08 PM   #4
Bend , Oregon
Glad I could help! it took me a while and tearing apart a lot of stuff (belly panel, corner bed, etc) to find my leak. The fix is easy once you find the problem.
That darned leak!! Need help from leak experts !! nickclifford General Repair Forum 20 12-03-2015 05:52 PM
2014 Interstate Lounge roof LEAK!!! lelaguna Sprinter and B-van Forum 14 06-25-2014 07:12 PM
Help! Water leak from fixture on '78 Excella water heater tank TimeLord Water Heaters, Filters & Pumps 3 11-11-2013 04:55 PM
Leak: Fired Up Hot Water, Now There's A Leak SSChanger Fresh Water Systems 4 07-15-2009 08:46 PM
possible plumbing leak or water leak jamesl Repairing/Replacing Floor &/or Frame 1 04-06-2003 10:52 AM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
