RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 11-23-2020, 03:49 PM   #1
2013 Interstate Coach
Kirkland , Washington
Water Intrusion
Need help identifying where water is entering my 2013 Airstream Interstate Lounge. The interior wall on the driver's side is wet next to the seat and down to the floor behind the couch in the rear lounge. The wet wall begins six inches below the side window and at the top of the exterior opening for the hot water heater. There is a small amount of water on the van floor between the wheel well and the rear of the van.
I dried the wall and the floor but have been unable to identify where the water is coming in. Used a garden hose to spraying around the hot water heater, magnetic door knob, side window, and roof. Anyone have a leak in this area and identified the source?
CNorm
CNorm is offline   Reply With Quote
Old 11-23-2020, 03:54 PM   #2
Just an old timer...
85MH325's Avatar
2004 22' Interstate
Tipton , Iowa
Images: 37
If you sprayed the exterior with water, and you're sure it's not coming in there, I'd check the inside plumbing.
Without knowing exactly what water heater setup you have, I'd be suspect of a water heater connection. Have you charged the system and looked to see if you have water system leaks?
AIR 2053 Current: 2004 Airstream Interstate "B-Van" T1N Sprinter & 2006 Born Free 32 RQ Kodiak Chassis
Old 11-23-2020, 06:02 PM   #3
Idaho Falls , Idaho
We had a leak on that side that came from the large side window behind the driverís seat. The seal had failed and we had to have the window rebedded.
Water can travel a long ways. One way to check if it is window is to check if any of the insulation in the walls that you can get to is wet. If it is wet above any of the plumbing there is a good chance it is a window.
Passin Thru is offline   Reply With Quote
Old 11-23-2020, 07:05 PM   #4
Raymond , Iowa
To have it come from the water heater and hit the wall it would have to spray - which would be a huge leak. Try leaving the pump on and see if it cycles. If it does that would suggest an interior plumbing leak. If not you are right to look for a leak from the outside.
We had a roof leak that only occurred when the rear of the van was up - like we park when camping so our heads are up a bit. It never leaked sitting in the driveway - nose up. Try reorienting the van with different sides up and repeat the hose test.
Titus is offline   Reply With Quote
Old 11-24-2020, 08:46 AM   #5
Thank you for the responses!
My fresh water system was drained including hot water tank and low point drains. Water intrusion is discovered when the rear of van is lower. If front is lower I can not duplicate or find any indication of water intrusion. I inspect the interior weekly including all upper cabinets and sidewalls. Will investigate the sidewall below the sink and behind the refrigerator more. I suspect the side windows as the roof caulking inspection looked good before and after water testing and is regularly maintained after finding a leak from the TV antenna wires when I bought the van 3 years ago.
CNorm
Water Intrusion CNorm Forum Admin, News and Member Account Info 0 11-22-2020 01:45 PM
Rear Water Intrusion junebug76 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 02-20-2019 06:48 AM
Water intrusion at rear bumper - What years affected? RFP Repairing/Replacing Floor &/or Frame 44 06-28-2018 03:02 PM
Water Intrusion lukeysh714 2016 - Current Classic (all lengths) 20 11-21-2017 09:36 AM
pardon the intrusion Y2k_Knight Our Community 2 04-06-2009 10:26 PM
