Old 09-07-2020, 04:11 AM   #1
Mansderm161's Avatar
Wilmington OHIO , Ohio
Water in rear tail light
I get water in rear drivers tail light with rain. From the outside, everything looks good and aligned. This has also caused some erosion, because I can see rusty water inside when it's wet. The water evaporates when dry, so there's a gap somewhere. Any suggestions? Heading to Airstream...want to make sure they correct and repair and don't want a back and forth between Mercedes and Airstream.
Mansderm161 is offline   Reply With Quote
Old 09-07-2020, 06:46 AM   #2
1972 23' Safari
Middletown , Rhode Island
Ive heard that some people will drill a small hole at the bottom of the tail light for water drainage.
Mx468 is offline   Reply With Quote
Old 09-07-2020, 06:54 AM   #3
Prof. of Pending Projects
wachuko's Avatar
2018 Tommy Bahama Interstate
Ocala , Florida
Cracked taillight or bad seal somewhere... that is all Mercedes, not Airstream.
Safe travels!
Wachuko
WBCCI #26769
2018 Airstream Interstate 3500 Lounge EXT Tommy Bahama w/ARS
wachuko is offline   Reply With Quote
Old 09-07-2020, 02:14 PM   #4
"Cloudsplitter"
Yep...especially with LED's,(no heat to rid the H2o).
The main reason all "Cloudsplitters" teardrops are still incandescent with a hole.👍
I’m an AS owner, and I'm really good at fixing things that aren't broken.
Old 09-20-2020, 06:06 PM   #5
You were right. Heading to Mercedes next. It's always something!
LED light kit for the Monarch stop tail and turn light Dan@LED4RV Commercial Listings 6 07-03-2018 11:26 AM
Tail Light and Marker light lens 68 TWind General Repair Forum 0 06-26-2014 11:34 AM
Leak near tail light, but it's not the tail light adwriter73 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 7 03-31-2013 11:34 AM
'71 safari tail light/brake light issue TGK Lights - Interior & Exterior 8 08-20-2011 05:45 PM
