1995 19' "B" Van Airstream 190
Lehigh Acres
Water heater not working
I have a 1995 B190 motor home. I am on vacation and the water heater isn’t working. When turning it on, I hear the igniter work the light goes off inside. Then, the light turns back on.
Are you out of propane? Does the stove light to verify that you have propane ? Do you have 12 volt power to the heater board? What voltage are the batteries? All of the above will cause problems lighting the water heater. Check all of these, then look at the burner orfice to see if plugged. Good luck Chris
ACI #7394
2012 GMC 2500 HD Duramax Denali
1994 Excella 34'
1987 Limited 34', 1976 31', 1976 Argosy 22' Gone to new homes
Hensley Hitch
