Old 05-18-2020, 01:37 PM   #1
St amant , Louisiana
Van controls at fingertips via the Vegatouch Mira
Anyone add the Vegatouch Mira to get the firefly control on the phone or device?
SwampRV is offline   Reply With Quote
Old 05-18-2020, 03:59 PM   #2
Sag Harbor , New York
Van controls at fingertips?
You mean you could sit in the back seat and drive the van?
Old 05-19-2020, 06:20 AM   #3
That would be sweet
Old 05-21-2020, 08:53 PM   #4
2019 Interstate Grand Tour Ext
Redwood City , California
I purchased the Mira module from Vegatouch directly and installed it myself. Very easy to do and it allows me to control everything the Firefly panels control on my smartphone. Cost was about $550 so it is not cheap. There is also a different module that will allow you to control everything while away from the coach as long as it has an internet connection and the cost goes up to over $800.
Really didn’t need it but I am a gadget guy plus I can mess with my wife when she turns on the lights or the fan and I can turn them off without her knowing it.
Jbrewco is offline   Reply With Quote
Old 11-27-2020, 08:31 AM   #5
2021 Interstate 24GL
Los Angeles , California
Thanks SwampRV. I’m quite interested in this solution. Can you describe what was involved in the installation and how you created the network connection for your smartphone’s connection?
gizmo-mobile is offline   Reply With Quote
Old 07-16-2021, 12:39 PM   #6
2021 Interstate 24GT
Magnolia , Texas
I recently added the Vegatouch Mira module described above, which is the BlueTooth module (~$550). I did not like the idea of having to pay $300 more, plus a monthly fee for their "Eclipse" WiFi version.
The install literally took 2 minutes. You access any one of the existing FireFly connections, the easiest for me was the one in the overhead driver's side locker. Then you unplug the orange cable from the FireFly touchpad and plug that cable into a splitter along with two other supplied cables. One of the new cables goes to the Mira module and the second one goes back into the touchpad. I then tucked the module into the locker behind the touchpad screen.
The Vegatouch app gives you all the functionality on the phone as you have on the screen. It’s definitely not necessary, but it's nice to have if, for example, you're cruising down the road and forgot to turn off the water heater, or you're sitting outside under the awning and want to turn on the exterior lights.
WeekendBob is offline   Reply With Quote
HItch ball height via AS and via Leveling mefly2 Hitches, Couplers & Balls 5 03-13-2012 01:56 PM
Ac/heater Controls In Dash mlmarch Classic Motorhomes 4 02-19-2007 02:13 PM
Cruise controls & wet/slippery weather loudruff On The Road... 12 10-31-2006 12:30 PM
Furnace Controls The Flintstones Furnaces, Heaters, Fireplaces & Air Conditioning 11 09-21-2006 01:27 AM
Remote mirror controls Astrodokk Airstream Motorhome Forums 3 10-02-2003 05:04 PM
