Old 11-08-2019, 12:29 AM   #1
ScottP's Avatar
2020 27' Globetrotter
2019 Interstate Lounge Ext
Jackson Hole - Tetons , Wyoming
Two week dry storage parking - master on or off?
With a 2018 or 2019 Multiplex coach...
If i turn the Multiplex master switch “off” at the sliding side door...
I’m assuming solar is direct wired, and coach batteries will still be charging?
Parking lot, no shore power available, Fusion cutoff switch installed
Thank you -
Conversely ~
If plugged in to shore power:
iirc, with Multiplex Setup, the master is turned “on” to accept juice from shore power.
I’m old, sometimes I get the rules for the master mixed up with the different year coaches.
ScottP is offline   Reply With Quote
Old 11-08-2019, 06:05 AM   #2
Brezzin's Avatar
Lakewood Ranch , Florida
in my experience with the Master Switch turned off, all charging of the chassis battery stops whether on shore power or solar. Thats because the charger/inverter gets turned off too. I suggest that you turn off the fridge and fusion. Keep the master on and solar should keep everything up and running just fine. Now if your ok with the chassis battery not trickle charging then your right, the solar alone will keep the house topped off.
Brezzin is offline   Reply With Quote
Old 11-09-2019, 11:00 AM   #3
ScottP's Avatar
To Dry or Not to Dry...that is the question 4riveteers Dehumidifiers & Ozone Generators 12 11-12-2019 09:32 AM
Parking for a week in Southern CA or AZ Jenniflow On The Road... 2 11-03-2019 11:06 AM
How Do You Blow Dry Hair while Dry Camping tburnand On The Road... 88 09-16-2018 04:29 PM
Master switch / Storage question polarlyse Winterizing, Storage, Carports & Covers 1 05-16-2011 06:26 PM
