Old 11-28-2019, 11:42 AM   #1
Beemerman's Avatar
2020 Interstate 19
Pensacola , Florida
Angry TV inputs
Having trouble figuring out what the HDMI input does......antenna input should be rooftop ant input....no? Then what signal comes via HDMI. Am getting continuous “check signal input” on tv.... button is “in” green light on......
‘20 IS 19’ TB, 2wd
Pensacola,FL
Beemerman is offline   Reply With Quote
Old 11-28-2019, 12:33 PM   #2
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
On my trailer the HDMI is from the Blu-ray player.
kscherzi is online now   Reply With Quote
Old 11-28-2019, 12:36 PM   #3
Beemerman's Avatar
2020 Interstate 19
Pensacola , Florida
Input isues
Kscerzi..... was that way on my EXT..... the Baby “B” doesn’thave a dvd player 😔
‘20 IS 19’ TB, 2wd
Pensacola,FL
Old 11-28-2019, 01:56 PM   #4
Half a Rivet Short
Carlisle , Pennsylvania
Hi
If there is nothing plugged into the HDMI *and* you switch to that input, you will get a "check input signal" message. It is telling you that you have switched to an input that has nothing on it. If you do not have a DVD player or satellite receiver, that's what you will see.
Old 11-28-2019, 02:54 PM   #5
Beemerman's Avatar
2020 Interstate 19
Pensacola , Florida
Angry Input issues
Bob.... there is an HDMI input plugged in.....could be for an aux video input.... there is a coax wire also attached ad the “ant” input......still say check signal when I select “Ant” as input.............??
‘20 IS 19’ TB, 2wd
Pensacola,FL
Old 11-28-2019, 04:28 PM   #6
mpsgolf's Avatar
2015 28' International
Ofallon , Missouri
On my 2015 Intnl....
HDMI goes from blu ray to tv. Outside antenna and cable input go to tv also not thru HDMI.
Audio OUT from tv goes to radio unit so tv and blu ray sound will play thru speakers.
I select antenna as the source on the tv and turn on antenna power to watch over the air. Select Cable as the source when cg has cable and turn antenna power off.
I only select HDMI as source on the tv when watching blu ray player. Since the radio unit does not have HDMI input, the HDMI cable goes directly to the tv and you have to get the blu ray audio thru aux port on the radio.
Hope this answers your quest???
mpsgolf is offline   Reply With Quote
Old 11-29-2019, 09:47 AM   #7
Half a Rivet Short
Hi
Do you have a DVD / Blu-ray player? If not, then look for an HDMI jack up by the rest of the entertainment gear.
Old 11-30-2019, 11:28 AM   #8
Beemerman's Avatar
2020 Interstate 19
Pensacola , Florida
Exclamation Inputs resolved‼️😆
Did an inspection of the 75 ohm antenna connector to TV....center wire was bent significantly..... straightened out, carefully attached & voila ‼️Worked as advertised‼️
The HDMI input to TV is pre-connected from the “pigtail” in cubby below TV mount. You don’t a disc player with the Baby B (IS 19) like the EXTs, but it is prewired where most peeps would put a player......
Thanks to all who helped me think of possibilities....
I was about to blame the antenna/booster......all work correctly
‘20 IS 19’ TB, 2wd
Pensacola,FL
Old 11-30-2019, 11:55 AM   #9
Contributing Member
Pahaska's Avatar
Austin (Hays County) , Texas
Simplification
The HDMI switch is overkill.
I completely removed the HDMI switch and disassembled the box the switch and DVD player were mounted in. I kept only the bottom of the wood box and cut an inch off each end to match the size of the DVD player. I kept the bottom because it tilts the DVD player up enough to clear the slides for the glass.
I replaced the switch with a two-way splitter that automatically connects to whichever HDMI output cable is connected to a powered device. I just need to power on whichever TV we want to watch and switch that TV to HDMI.
Amazing how much useful space I have in that cabinet now. That wood box was assembled with 6 screws and 6 dowels. No wonder these things cost a fortune.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
Old 11-30-2019, 01:06 PM   #10
Beemerman's Avatar
2020 Interstate 19
Pensacola , Florida
Thumbs up HDMI controller
Pahaska..... that whole control unit was ridiculous on my ‘19 GT EXT...... too much circuitry for a simple issue ‼️
‘20 IS 19’ TB, 2wd
Pensacola,FL
Old 11-30-2019, 02:38 PM   #11
Contributing Member
Pahaska's Avatar
A famous 1930s aircraft designer was asked for his method. His answer was "Simplificate and add lightness." This fits with what I tried to do on every Airstream I have owned (5).
John W. Irwin
WBCCI #9632
tv headphone and a/v inputs whitevan Electronics & Connectivity 1 02-01-2015 02:42 PM
Confused about front and side electrical inputs cdanj Electrical - Systems, Generators, Batteries & Solar 3 10-19-2014 09:12 PM
HDMI Switcher with 3 inputs ghaynes755 Audio, Video & TV 1 04-29-2014 08:42 PM
How to replace the Cable/Phone inputs deauxrite Phone, CB & Ham Radio 3 04-09-2010 06:35 AM
Three Landline Inputs highlander Electrical - Systems, Generators, Batteries & Solar 1 04-09-2005 07:44 PM
