Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 10-17-2020, 01:13 PM   #1
The Gadget Guru
Airstream - Other
2021 Interstate 24GT
Golden Oak , Florida
Tricks for Drawers Opening?
New Interstate 24 GT owner here. It seems that a couple of drawers like to open when taking turns. Yes, I drive slow through the sweepers? Simply stated, what I thought were locks don't seem to be effective. Any tips or tricks?
GadgetGuru is offline   Reply With Quote
Old 10-17-2020, 01:23 PM   #2
Piggy Bank's Avatar
2019 27' Flying Cloud
Kansas City , Missouri
Order some gaffer tape on Amazon. Easy solution. Leaves no sticky residue.
Piggy Bank
Piggy Bank is offline   Reply With Quote
Old 10-17-2020, 02:36 PM   #3
2017 Interstate Grand Tour Ext
Englewood , CO
We have a 2017 GT. I upgraded to 10lb latches. The standard I believe are 3lb latches. A bit tougher to open but it solved the problem. Easy fix.
Welcome to the club.
5280BDocker is offline   Reply With Quote
Old 10-17-2020, 02:42 PM   #4
Englewood , CO
Note sure your year but these are the latches I used. You only need to install the latch itself and reuse the receptor on the drawer.
Old 10-17-2020, 04:55 PM   #5
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
Check this thread for a product posted frequently over the years:
https://www.airforums.com/forums/f7/...ml#post2341551
Own your trailer long enough and you will learn some of the products Airstream chose to include function poorly or have a short lifespan. The plastic latches are among the poorer choices and fail way too frequently. Get the brass ball latches and they will outlast your ownership.
Sir Tristan
Air #48582, S/SO #003, WBCCI #4584
SeeMore is offline   Reply With Quote
Old 10-17-2020, 09:39 PM   #6
The Gadget Guru
Airstream - Other
Thanks for the responses. New latches ordered!
Old 10-18-2020, 11:35 AM   #7
solomon.m's Avatar
2020 27' Flying Cloud
Livermore , California
Airstream part number 381228-01 is 10 lb latch That you can use to replace the lighter version currently installed
solomon.m is offline   Reply With Quote
Old 10-18-2020, 12:15 PM   #8
Contributing Member
Pahaska's Avatar
Austin (Hays County) , Texas
2018 GT. My wife could not handle the 10# latches and, at 88, I have poor hand strength. The 10# solution did not work for us.
I replaced 5 of the heavier drawer galley latches with locking latches from Amazon. Several of the drawers were easy because they had a surface above them to place the catch. On the other drawers, I installed the latches upside down with a post that engaged a catch under the drawer.
The new latches are close to the appearance of the originals and retract like the originals.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
Pahaska is online now   Reply With Quote
Old 10-19-2020, 03:24 AM   #9
Adams Run , South Carolina
If itís a stack of drawers stick 1 long wooden dowel thru all the handles.
Markhambryan is offline   Reply With Quote
Old 10-19-2020, 07:58 AM   #10
Contributing Member
Pahaska's Avatar
Pretty hard to find drawer handles on an Interstate. This started as an Interstate thread and went astray like so many threads do.
John W. Irwin
WBCCI #9632
Old 10-19-2020, 08:13 AM   #11
2017 25' Flying Cloud
Woodway , Texas
Unintentional Drawer Deployment
You might also look at some of the childproofing latches that go on the cabinet doors and drawers on the inside.
Was installing some of these for in my daughter's home and thought they might be a good fix for our AS.
Be careful, though; some are accessed by the fingers when the drawer's barely opened and are easy to use while others require a magnetic 'key' placed against the outer, opposite side of the door. This could be a nuisance if the key's misplaced or used frequently.
emelaich01 is offline   Reply With Quote
Old 10-19-2020, 12:46 PM   #12
2007 22' International CCD
Admittedly the issues are a bit different in an Airstream trailer, but here is what I use:
I have a couple drawers in the rear desk that used to launch out onto the floor with heavy braking, especially in Phoenix traffic! I used stick-on childproofing straps that wrap around the corner of the cabinet to the drawer front. They unlock with a finger press on the latch. The adhesive works loose in the heat, but sticks right back on. These do not mar the surface of the laminate.
On the kitchen side I use a long adjustable nylon strap and footman loops screwed down in strategic spots to hold the wardrobe, fridge, and oven door firmly shut on the road. This helps with the hard dodge traffic maneuvering in Phoenix as well.
Avoiding Phoenix traffic is, of course, the easiest solution.
Old 10-19-2020, 01:02 PM   #13
Halford1's Avatar
2019 19' Flying Cloud
Canyon Country , California
Surprised that Airstream doesn't install good latches. Coleman Popups (once king of all Popups) has fancy feature to prevent accidental drawer openings.
You can use earthquake latches like we do on cabinets in California.
2014 Ford Explorer XLT with factory installed Tow Package.
2019 Flying Cloud 19CBB
Halford1 is offline   Reply With Quote
Old 10-19-2020, 06:41 PM   #14
Atlanta , Georgia
My drawers kept opening when making a right turn in my 2020 GT. I told my dealer about the issue and they replaced all of the latches with 10 lb latches. I haven’t had a problem since.
Coffee Break is offline   Reply With Quote
Old 10-19-2020, 07:33 PM   #15
LAWBC's Avatar
2013 27' FB International
2012 23' Flying Cloud
GVA , British Columbia
Neodymium Disc Magnets
Neodymium Disc Magnets, but I would use a piece of metal on the opposite side these babies are powerful
https://www.amazon.ca/gp/product/B07...?ie=UTF8&psc=1
Laurence
LAWBC is offline   Reply With Quote
Old 10-20-2020, 08:49 PM   #16
Barretta2's Avatar
2013 23' Flying Cloud
Naples , Florida
With these work on a Flying Cloud as well?
Barretta2 is offline   Reply With Quote
Old 10-25-2020, 10:39 AM   #17
Acton , Ontario
I got some magnetic child locks for my sport 22fb and they work flawlessly ! I have a magnetic knife holder mounted so I keep the key on it when traveling.
https://www.amazon.ca/Safety-1st-00H...s%2C159&sr=8-4
sinfulpride is offline   Reply With Quote
Old 10-25-2020, 11:32 AM   #18
2019 23' Flying Cloud
Eagle Point , Oregon
Straps!
See attached
A.S. Beauty is offline   Reply With Quote
Old 10-25-2020, 12:59 PM   #19
RollingCasita
As 5280BDocker answered, I also ordered latches from Amazon, but just 8#. So far so good. And as he said, you can just use the existing holes and catch.
eddieburns is offline   Reply With Quote
Old 10-26-2020, 12:43 AM   #20
2014 27' FB International
Bend , Oregon
Drawers open
I made a video while driving down a winding road, doing the speed limit, showing my drawers flying open and closed. I showed the video to the dealer and they installed latches with a higher pound rating to open. Now they stay closed better but not great. It takes two hands to open them sometimes, not always easy. Airstream needs to fix this
BruceTami is offline   Reply With Quote
storage drawers/ kitchen drawers pdmcrim86 Airstream Classifieds 3 09-10-2020 09:55 AM
Backing up - Tip & tricks LI Pets Towing, Tow Vehicles & Hitches 59 08-10-2018 03:29 PM
Backing - Method, Tricks, Pointers??? kudzu Community Polls 14 05-30-2006 08:36 PM
Stupid human tricks, part 2 74Argosy24MH Off Topic Forum 9 12-22-2002 02:14 PM
Stupid Human Tricks airstreamcaravel General Repair Forum 12 11-20-2002 03:08 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
