I bought a set of battery-operated wireless tow lights for use in the Smart under tow. The transmitter plugs into the 7-wire socket, under the AI rear end.
The lights are on at low intensity and serve as running lights whenever they are switched on. The transmitter connects to three wires in the AI connector: ground, left turn, and right turn. I have tested the transmitter on the bench with a
12v power supply and the lights work perfectly.
When plugged in to the AI, the brake lights operate properly, indicating signals on both left and right turn pins. However, the turn signals do not work unless I have my foot on the brake. Then, they work properly with one half at hi-intensity while the other half blinks. If I take my foot off the brake, there is no reaction to the turn signals.
It appears that the left and right turn pins in the AI connector do not pulse unless I have my foot on the brake.
Has anyone encountered anything similar?
