Old 04-05-2020, 01:41 PM   #1
​2020 Atlas​
Cleveland , Georgia
Question Towing a Prius behind an Atlas
Hi there again,
We recently acquired an Airstream/Mercedes Atlas. We want to tow our Prius V behind it on long trips. The Prius weighs about 3400lb total of which about 1800 is in front. I've been looking at tow dollies and have some questions:
1. There are many brands: Blue Ox, Roadmaster, Ultra Tow, Premier, Stehl, Demco. Which one is best for our needs?
2. Should we go with surge brakes or electric brakes?
3. Do we need an anti-sway hitch with our relatively light load?
Much obliged for any advice from people with experience.
Krikati
Krikati is offline   Reply With Quote
Old 04-05-2020, 01:45 PM   #2
Long Island , New York
Does Toyota allow that?
https://duckduckgo.com/?t=ffnt&q=toy...hind+RV&ia=web
Only with front wheels up on a dolly?
https://priuschat.com/threads/towing...d-an-rv.20359/
Is yours 2WD or 4WD? It appears that drive wheels cannot be on the road. Please advise what you find out from the dealer and other sources.
Good luck,
Peter
PS -- What does your Prius owner's manual say?
OTRA15 is online now   Reply With Quote
Old 04-05-2020, 02:46 PM   #3
​2020 Atlas​
Cleveland , Georgia
Many thanks Peter. I've read a good bit on line, and it's pretty clear the Prius can be towed with front wheels off the ground. But the question that remains is this: when you push the button to turn off the ignition, the parking brake automatically engages. If the parking brake locks the rear wheels, it will either wear out the pads or the rear tires, won't it? On the other hand, if you run it with the ignition "on" won't that create issues with the electrical system? Also, the steering will not lock with the ignition on. Help!
Old 04-05-2020, 05:36 PM   #4
Call your Toyota dealer, or their 800 number IMO. Is your Prius owner's manual silent on this? Getting an exact answer may be hard, and may be different for each model year. Very easy to over-think this, before getting a definitive answer from Toyota IMO.
We have had a couple of Prius V's -- great car!
Peter
Old 04-05-2020, 11:50 PM   #5
jcl
Vancouver , British Columbia
The Prius manual on line says you must use a tow dolly (front wheels off the ground). It says the vehicle must be on, for two reasons. The first is the parking brake, as you note. The second is that the steering wheel lock is not designed to be strong enough to keep the front wheels straight. when towing on a dolly.
You need trailer brakes for that weight. Whether you use surge brakes or electric brakes may be dependent on your state rules. They vary as to the legality of surge brakes over a certain weight. The tow dolly supplier will know. If you opt for electric brakes you have the additional benefit of manual application.
You don't require weight distribution equipment as the tongue weight is so low.
Having used a tow dolly, they can be a hassle. Loading and unloading ease will depend on how low the front air dam is on the Prius. Remember that there is no operating in reverse. But if you have the Prius already it is probably simpler to tow using a dolly than purchase another vehicle that you can flat tow.
Good luck
Jeff
jcl is offline   Reply With Quote
Old 04-06-2020, 09:04 AM   #6
weirdstuff's Avatar
2018 23' International
San Diego , California
A good friend of mine wanted to tow her Prius behind her motorhome. She said she couldn't flat tow it, and sold her Prius and bought a different car to tow.
weirdstuff is offline   Reply With Quote
Old 04-06-2020, 09:17 AM   #7
Coloradobus's Avatar
Towing a low to ground profile car like Prius, or any other you want a “tow dolly” with detachable ramps. Given motion of your Atlas’ rear end driving over humps or in and out of parking lots the hitch will raise up and down. As you raise up dolly tongue the attach ramps move away from car. As the dolly lowers the attached ramps can bite into under suide of you car . That while you want detachable ramps.
Braking: personally i would choose surge brakes.
JIM n CHRIS
‘62 Overlander 26 ft. ATW Yeager trailer #5289
"62 Airstream 22ft. ATW Hall trailer #83,’90 SQ Sream, ‘06 Bambi Q/S, Prevost Featherlite 45ft, GMC/ Bigfoot camper
Coloradobus is offline   Reply With Quote
Old 04-06-2020, 09:47 AM   #8
kidjedi's Avatar
1972 25' Tradewind
1976 31' Excella 500
1974 31' Excella 500
1975 24' Argosy 24
Denver , Colorado
I will be curious as to what you find. I think a full platform is probably the way to go, and a custom trailer is probably the best option (you can make it lighter than a stock trailer, and just the length of your vehicle). I am considering pulling my Prius behind the Argosy 24 motorhome and using it for an auxiliary battery bank. Toyota will tell you not to do this, but there are plenty of documented cases of people using their Priuses (Priui?) for house power (plugged into their home's breaker box) during natural disaster power outages, so powering a motor home should be cake. On a related note: I am hoping to eventually place Tesla type battery banks in the belly of an airstream for house power *and* auxiliary power (to increase distance) for an electric tow vehicle!
25' 1972 Airstream Trade Wind Land Yacht (heavily customized)
2006 Jeep Liberty CRD (diesel)
BeahmStream.com
kidjedi is offline   Reply With Quote
Old 04-06-2020, 09:50 AM   #9
Mikebrady62's Avatar
2019 27' International
Rogers , Arkansas
I do not have specific experience towing a Prius but I would use a sway control hitch. I don't like even a little sway when towing. The short distance from your hitch to the wheels is not the best for that.
Mikebrady62 is offline   Reply With Quote
Old 04-06-2020, 10:53 AM   #10
​2020 Atlas​
Cleveland , Georgia
Many thanks to all. So, I am tending towards a Roadmaster Tow Dolly with electric brakes. I don't know if the ramps are removable. Are they? Is the premium model Roadmaster worth paying double for?
Old 04-06-2020, 12:14 PM   #11
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
The RM2000-1 (premium model) has some better user ergonomics and a wider range of adjustment. But both are decent products.
Ramps are not removable on either model. But they're not terribly long, either. The bed tilts to provide access for loading the car, then is leveled out and pinned in place for transport. Unless you expect to bottom out your Atlas's rear bumper on the pavement on a bump or incline, the vertical range of motion of the dolly tongue should not cause any more problems than will the car's front suspension flexing on the dolly when the dolly wheels hit a bump.
The Roadmaster 2000-8 Guardian Carrier is a good accessory for either dolly, coupled with the model 4000 Guardian rock shield, to protect your Prius from road debris that might be thrown up by your Atlas.
Old 04-06-2020, 07:48 PM   #12
Just an old timer...
85MH325's Avatar
2004 22' Interstate
Tipton , Iowa
Images: 37
I'll give you a little different perspective. I'm a veteran over the years of five different tow dollies. I'm a slow learner, but I have since seen the light, and bought a towed that can be towed 4-down. But I understand needing to tow the car you have.
I towed a '10 Prius level V with the last tow dolly I bought. After having four REALLY heavy ones, like the Roadmaster, Tow Master, and Demco the last one I bought was one of the light-weight ones. Believe me, there are MANY "down sides" to tow dollies, but the biggest is weight. Moving a tow dolly by hand from a rutted, wet campground road into a soft, wet campsite in the rain AFTER you've had to crawl around underneath it in mud puddles to get the straps off is no fun at all.
The last tow dolly I bought was a lightweight dolly like the EZ-Tow, Acme and similar. They're a third the weight, a third of the cost (of some of the big boys) and MUCH easier to muscle around when and where you need to. They work REALLY well without the steering axle or pivot plate, and just with the steering on the car as the pivot.
Now, my '10 Prius was pretty straight-forward with a hand parking brake, and no steering lock at all, so the car was towed with the transmission in "park" and the brake off, and the ignition switch off. I don't know about the later Prius models... and you can't tow anything from Toyota that is AWD or 4WD, even with the dolly because of the center differential. I found THAT out the hard way with my FJ Cruiser. I towed IT on the dolly, and STILL had to drop the rear driveshaft. *sigh* As I said, I'm slow learner.
I didn't have brakes on any of the tow dollies, and even towing a Lincoln Continental behind my Airstream 325, I never had issues. That said, I DO have a brake buddy in my Jeep when I tow it 4-down now.
So there you have a little different perspective. Good luck!
AIR 2053 Current: 2004 Airstream Interstate "B-Van" T1N Sprinter & 2006 Born Free 32 RQ Kodiak Chassis
Old 04-06-2020, 11:22 PM   #13
c21
2014 Interstate Coach
Arroyo Grande & Central Point , California & Oregon
For a little different perspective, a year ago I did an extensive search for a toad to flat tow behind our Unity RV. We wound up with an 18 Fiat Abarth for several reasons. 1. It was about the 3rd lightest vehicle in the MH Magazine tow guide, 2. Didn't require any special procedures like removing fuses or disconnecting battery etc. 3. Doesn't require the ignition to be on while towing, just take it out of gear and release the parking brake, lock the doors and go, and 4. Dealers were deeply discounting the 2018's at this time last year. I had found several new 2018 Fiat 500 Pops at 30% under MSRP but wound up buying an Abarth model at 25% under MSRP. The only drawback to the Fiat is an un-useable rear seat which I solved by installing a seat delete kit which gave us a much larger flat storage area. I had it set up for towing by Camping World and was fortunate to catch their $59 installation sale. All in all we're very happy with our choice but unfortunately they will no longer be importing them to the US. If anyone decides to look for a Fiat, be sure to limit your search to stick shift versions, the automatics are not flat towable.
c21 is offline   Reply With Quote
Old 04-23-2020, 05:57 AM   #14
1999 19' Bambi
Morrison , Colorado
Towing a prius
Be aware of the campground policy on charging!!
Pruckles is offline   Reply With Quote
Old 04-23-2020, 08:16 AM   #15
Mollysdad's Avatar
First, look at the Prius manual under "recreational towing". See if there's a plan.
I had a tow dolly for a while, sold it with the MH, and the buyer used it with his Prius. It was a Demco.
The big hassle with a dolly is storing it while not in use.
No, you do not use a WD hitch, it's just a 2" ball.
Mine had surge brakes and they worked fine. Electric brakes would require wiring a brake controller into your RV.
The tow dolly had a simple 4 pin electrical connector.
2020 Atlas towing capacity - 7500lbs jasperkins Sprinter and B-van Forum 25 03-21-2020 04:48 PM
Atlas Owners? or Anyone with Atlas knowledge foleyx4 Airstream Motorhome Forums 10 01-20-2020 02:42 PM
valve behind heater? water pipes behind refrigerator? daa1111 Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 4 05-22-2018 04:45 AM
Towing A Jeep Behind 39' As Deisel TENX53 General Motorhome Topics 2 06-17-2003 08:55 AM
Towing a Small Motorcycle Trailer Behind 25' Safari?? heyskipper Our Community 4 05-07-2003 11:23 AM
