11-21-2015, 08:13 AM
#21
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
Originally Posted by Ynefel
I was reading my Sprinter manual this week and it stated that 'this Sprinter is equipped with a TPMS.' It wasn't listed as an option.
Sprinter 2500s are required by Federal Motor Vehicle Safety Standard 138 to be equipped with TPMS. Sprinter 3500s are not required to have TPMS because they have a GVWR over 10,000 pounds, and therefore meet one of the few exceptions in the FMVSS. The Sprinter manuals cover both the 2500 and 3500 models, so just because the manual refers to them doesn't necessarily mean your van came with them.
In addition, even if the stock Sprinter 3500s came with TPMS (they didn't) that would have been for the original steel wheels, not the aftermarket Alcoa aluminum wheels installed by Airstream.
11-21-2015, 10:46 AM
#22
2015 Interstate Grand Tour
Southaven
, Mississippi
Originally Posted by c21bill
The TPMS system is easily installed by the user.
I am not mechanically inclined, will this be easy for me to install? If I don't need to pay someone to install that would be great.
11-21-2015, 02:07 PM
#23
2011 Interstate Coach
Overland Park
, Kansas
You'll need to replace the valve stems w/ the ones referenced in Post #17 unless you opt for internal TPMSs. Either way you'll need to break the tires down. Probably not a DIY job.
2011 Interstate SOLD! Upfitted 2017 Transit 350. SOLD!
11-21-2015, 02:22 PM
#24
2016 Interstate Lounge Ext
Pittsburgh
, Pennsylvania
I just had my tires balanced (the factory does not balance the wheels). If I have to have the wheels broken down will I need to rebalance the wheels?
11-21-2015, 02:34 PM
#25
Overland Park
, Kansas
If they mark the position of the tire on the wheel and carefully remount it, then technically you shouldn't need to rebalance. I've had that done when replacing the TPMSs on my Tahoe where they didn't actually remove the tire but just broke the bead next to the sensor and replaced it w/o moving the tire wrt the wheel. They should be able to do that when putting on the new extension valve stems.
11-22-2015, 06:19 AM
#26
Southaven
, Mississippi
I plan on replacing the stems with dually's. Once that is done, is the TPMS a self-install project?
11-22-2015, 09:45 AM
#27
2014 Interstate Coach
Arroyo Grande & Central Point
, California & Oregon
The Truck Systems Technology TPMS system is self-install. The included manual provides all the info you will need to code the sensors and program the system. The sensors are coded to their specific tire location so if you take them off you can return them to their assigned tire. By programming you will be setting the temperature and pressure parameters. The whole thing will take 30 minutes more or less. Once installed the monitor will cycle between each tire indicating the temp and pressure for that tire for about 5 seconds. You can hardwire your monitor or simply plug it into a 12v plug to recharge occasionally. A charge will last for about a week.
11-22-2015, 06:17 PM
#28
Pittsburgh
, Pennsylvania
Where is a good place to install the monitor for the TPMS?
11-22-2015, 06:40 PM
#29
Biloxi
, Mississippi
In a visible spot. Most seem to be mounted on dash or windshield.
MICHAEL
11-23-2015, 05:56 AM
#30
Southaven
, Mississippi
Appreciate all the good info. I will get this done before next spring.
11-23-2015, 10:43 AM
#31
Ravenna
, Ohio
Yup. External sensors just screw on like large valve caps. Turn till air stops leaking then another 1/2 turn should do it. There are little rubber seals inside that fit against the end of the valve stem. Don't over-tighten (no wrench or pliers required) as this can distort or tear the rubber seal.
11-30-2015, 09:46 AM
#32
Cumming
, Georgia
Install is Easy and we have tech support until midnight 7 days a week at 770-889-9102
Mike Benson
TST 770-889-9102
11-30-2015, 11:18 AM
#33
Tavares
Mike Benson
TST 770-889-9102
Mike - I need a basic 4 tire tpms; the ST507 on your site supports 22 tires at $259.
Do you have a less elaborate sensor unit that will work for only 4 tires at lower cost, or is the $259 unit the lowest price point you have?
Thanks...Rich
“Character is doing the right thing when nobody’s looking. There are too many people who think that the only thing that’s right is to get by, and the only thing that’s wrong is to get caught.” - J.C. Watts Jr.
12-02-2015, 02:53 PM
#34
Cumming
, Georgia
Thanks...Rich
Hello Rich,
Did you receive your system today? Call me with any questions.
Mike Benson
TST TPMS
770-889-9102
12-02-2015, 03:57 PM
#35
2013 30' Classic
Greenwood
, Mississippi
The Dill and other brands will work perfectly on an Interstate, but...
You must dismount the tires to mount the tire sensors. It would be best to wait till you are buying new tires anyway.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
12-02-2015, 04:02 PM
#36
2010 28' Flying Cloud
Lower Alabama
, USA
You can bust the bead and put internal sensors in without totally dismounting a tire. I had a tire shop do that to put in metal stubbies for me.
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
12-02-2015, 05:05 PM
#37
Rockwell
, North Carolina
That won't work on the Alcoa wheels on the Interstate.
12-02-2015, 05:30 PM
#38
Tavares
Hello Rich,
Mike Benson
TST TPMS
770-889-9102
Mike - Tracking indicates a Thursday delivery. I'll let ya know.
12-02-2015, 05:36 PM
#39
Overland Park
, Kansas
Why not?
12-03-2015, 11:16 AM
#40
Cumming
, Georgia
Yes they will work on Alcoa wheels on the interstate. TST also has internal that mount inside the wheel as well. Please feel free to call me to discuss. I am available until midnight @ 770-889-9102
Mike Benson
TST TPMS
