08-15-2018, 05:43 PM
Normal
Tire covers.
Maggie
08-15-2018, 05:44 PM
2013 30' Flying Cloud
Kingwood
Both from what i’ve See on YouTube, but most of us are belt and suspenders kinda people.
08-15-2018, 05:51 PM
Wheels Itch)(Must Travel
2014 25' FB Flying Cloud
- east coastal area -
Originally Posted by wachuko
I just bought 4 covers by KAKIT on amazon prime. They really look nice Abe were easy to use.
Bought the covers for the same reason I wear clothes: they protect my skin and I look a lot better.
08-15-2018, 05:57 PM
1965 22' Safari
Orinda
Both x2.
Special tire covers cost a fortune and don't last that long, when I always have scrap plywood for the job.
Commercial tires suppose to have 10 years life span. All subject to inspections.
08-15-2018, 07:15 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Both...👍 + a drainage tile just for THOI.😂
08-15-2018, 07:33 PM
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
I change the trailer tires every 4 years. I do not use covers.
08-15-2018, 07:59 PM
Prof. of Pending Projects
2018 Tommy Bahama Interstate
Orlando
We do the same with the boat trailer... in that one we do not even bother to get tires and mount them on the old rims. We just get the wheel set that comes already with tires mounted and ready to go... cheaper than buying a new tire... never understood that one...
Back to the AI, I already sprayed some 303 since I had it at home... so at least they have some protection.
I will get the covers if only to keep the rims clean while parked in storage. Lame excuse since those rims clean so easy with just a water and car wash soap...
I am already starting to work on my wife to convince her that we have to move to a house where we can park the AI inside the garage... I do not like having it parked in storage...even if it is only 5 miles away.
08-16-2018, 10:37 AM
New Orleans
, Louisiana
Tire covers
Plywood works great.....
08-16-2018, 11:01 AM
Orlando
At least the covers are flexible, collapsible and occupy little space when not in use...
Plywood? Realy? And then place a protector over the plywood to avoid it rotting
08-16-2018, 11:39 AM
2015 19' International
Boise
, Idaho
I use the snap ring tire savers by covercraft. Easy to “snap” onto the wheel.
08-16-2018, 12:16 PM
2018 25' International
Las Vegas
, Nevada
I made some out od black out curtin fabric following utube instructions. should last long
08-16-2018, 01:43 PM
2007 22' International CCD
Corona
303 UV Protectant, if that is what you use, needs to be applied to BOTH sides of the tire. (admittedly a total PITA.)
UV has this nasty habit of reflecting off pavement and getting to the back side of the tire...
I use both tire covers and protectant spray, and try to keep the AS in a shady area if possible. My covers wrap around the back of the tire somewhat...
08-16-2018, 02:16 PM
2018 Interstate Lounge Ext
LV
, Nevada
Believe me, I searched the forum... after 17 pages I stopped looking. Could not find a thread in this section about this.
With tires needing to be changed what? every 5-6 years... do I even bother using tire covers???
Or just use some 303 UV Protectant and call it a day??
WACHUKO - I have used both (not on AI) on a few of my cars for many years. My personal experience & opinions on them are:
- 303 Protectant works great. I have primarily used them, on my racing bikes that are bare titanium or bare carbon fiber. But they work great on rubber. I like them better than the tire treatments from the auto parts stores.
- If I was to store a vehicle outdoors for an extended period, I would probably use tire covers. But then again, if the vehicle does not have a car cover, then what is the point? And using a car cover on an outdoor stored vehicle presents it's own pros/cons. ROBERTCROSS made a good point on drain tile. While it may seem overkill, I had dry rotted a set of Michelin when I was living in San Francisco. I stored a vehicle outdoors on a gravel lot (not by choice). The rains, high humidity, poor drainage from tires, and constant UV exposure without being driven combined to dry rot the set in less than 4yrs. I doubt this will happen with your AI since you constantly use it.
- If I was planning on using the vehicle often anyways, I won't go through the hassle of tire covers. Regular washing and 303 in my experience is more than adequate even if my car stays outside 24hrs/ 365days. My 1979 Pontiac Trans Am which has seen it's share of harsh weather conditions being stored outside (Chicago, Los Angeles, San Francisco, Las Vegas) still has it's original BF Goodrich Radial T/A and cosmetically they are still perfect. Of course, those almost 40yr old tires will obviously never see the road, the car is just being stored for it's classic car status. On a vehicle that is regularly used/maintained, as you said, you would bump into the 5-6yrs of use expectancy of your set before UV damage or tread wear would be the overriding issue. I too plan on replacing tires in 6yrs. My friend replaces tires at 5 yrs on his Class A tag axle (8 tires, not even 20,00 miles, talk about expensive).
- Believe it or not, there was a reason I used car & tire covers EVEN when they were stored in garage. Many decades ago, I was convinced by an auto detailer to cover my cars right after it gets detailed even if storing in garage. He said covers should only be used on newly cleaned surfaces and to protect car from dirt and people/hazards even in garage. But it wasn't until we got our puppy golden doodle Belle that I used tire covers after detailing cars for storage. She decided newly cleaned car tires were better for pee-breaks than fire hydrants or light poles. To this day, I still cover tires when car is in long term storage. Old habits die hard
08-16-2018, 04:33 PM
Orlando
Thank you! Was not aware... I only applied it to the side facing out... good to know. Yeah, that is going to be somewhat of a PITA, and because of the size of these tires, I might need to buy it by the gallon...
- ...ROBERTCROSS made a good point on drain tile. While it may seem overkill, I had dry rotted a set of Michelin when I was living in San Francisco. I stored a vehicle outdoors on a gravel lot (not by choice). The rains, high humidity, poor drainage from tires, and constant UV exposure without being driven combined to dry rot the set in less than 4yrs. I doubt this will happen with your AI since you constantly use it...
Thank you Alex. As you can see in the photo, mine is also stored over gravel. I thought that was a good thing as it should minimize flat spots... but did not think about the issues related to humidity/rain puddles
08-17-2018, 09:15 AM
Orlando
Thank you all. Went with some inexpensive ones that fit 30"32" diameter tires. 4 covers for 24.99
https://www.amazon.com/dp/B07CXRDLGQ...ing=UTF8&psc=1
Now to buy that 303 in bulk, lol...
08-18-2018, 09:22 AM
2004 30' Classic Slideout
BARTOW
Tire Covers...
I've been wondering about this... are all AS tires the same size? I have a 2004 Classic 34...
08-18-2018, 09:28 AM
Overland Adventurer
2009 34' Panamerica
Telluride
My Airstream is always in motion. Despite being docked for as long as a month I don't bother with covers as I'm buying 6 tires every year. I'm the one guy on the forums who wears his tires out rather than having them time out!
08-18-2018, 10:32 AM
Orlando
6 tires every year?! That is a lot of mileage!!!
Mine will definitely time out, lol.
Silver covers ordered should be here tomorrow.
