I'm perfectly capable of figuring this out myself, EXCEPT, I really hate cracking good screw seals unless absolutely necessary, especially when they might penetrate the van body. I'm chasing a water leak and trying to rule in or rule out the awning as a possible source without pulling more stuff apart than I need to.
Have any of you removed your Carefree Freedom III manual awning, and if so, what can you tell me about it?
Airstream appears to have used the T1N Sprinter gutter as a
de facto rail mount in a way that is not consistent with the manufacturer's instructions (per the OEM installation manual, Carefree's parent company was envisioning a more conventional awning rail or mounting plate). Most of the weight of the awning appears to be sustained by the gutter, but it must also attach through the body side to keep it from pivoting down due to gravity.
Here are two annotated photos of what I THINK is going on. Is this consistent with your observations, if you have worked with your awning?
BTW, when I use the word "compression", I'm referring to the DIY gear replacement instructional PDF that one of our sometimes-posters put together a few years ago.
TIA.
