Originally Posted by Camerons
Has anyone come up with an idea on how to stop the main switches from being turned on or off by your hips on the way out the sliding door ? Is there some type of rocker switch shield that I can buy or build ?
CAMERONS - Since I do not have a GT, my setup is different and I can not fully appreciate the extent of the problem but I can envision what happens. Maybe boxing around or framing around the switches would be enough to solve it? You can fabricate out of wood (like a picture frame) or acrylic or plastic. You can even use weatherstripping foam temporarily just to try it's effectiveness.
If the side panel of that cabinet wouldn't require major disassembly to take out and put on a router table, I would router an opening for the switches and flush mount them. But that's way too much work.
