Originally Posted by swilly43
Lot's of variables to consider in getting solar output, including angle of incidence, dirt and temperature. I am often surprised at the low output at times when I think it should be higher. Then I get surprised again when the output is higher than expected.
Further, the panel and controller will not output more than the demand for charging and consumption.
For example, if your batteries are charged and there is no other demand from any other load, the output will match what is required for float charging.
I have been watching the output from my recently installed 100/30 and 300 Watts of panels. When there is bright sun and charging in bulk I may see 250 Watts, but under similar conditions when the batteries are charged, I may only see 40 Watts. As soon as I turn on a load, like the MaxxAir on high, the wattage (and amperage) jumps.
