Old 10-08-2020, 03:24 PM   #1
2015 Interstate Coach
MEDFORD , New Jersey
Steps Not Extending 2015 AI Lounge
STEPS WONT EXTENT, . I opened the slider, the steps extended, closed the slider, steps didn't close. i then started the vehicle, the steps closed with engine running. I turned the engine off, open the slider and the steps did not extend. Tried several times , cannot get them to extend. I don't have my fuse manuel with me. I believe its the fuse panel under the drivers seat, but i don't know which one. Any help appreciated..
RICKBETTY is offline   Reply With Quote
Old 10-09-2020, 08:36 PM   #2
2013 Interstate Coach
Idaho Falls , Idaho
On my 2013 the fuse is under the driverís seat. I believe it is number 10. It is the same fuse that controls the awning. Does it extend? If so it is not the fuse.
It sounds like it could be your door switch since it did close when you started your engine. On mine the door switch is a plunger type. I have read in this forum where many people have had trouble with their magnetic door switches. You might to use the search function about that.
Passin Thru is online now   Reply With Quote
F65 Awning not extending James415 Sprinter and B-van Forum 1 05-14-2019 09:55 AM
Extending Generator Run Time on Gas RichHog Generators & Solar Power 9 09-19-2010 06:26 AM
Extending the sofa on a 2005 Safari 25' FB mshamilton Upholstery, Blinds, Walls & Interior Finishes 3 09-09-2009 09:04 AM
Extending wet camping season JimC Winter Living 3 09-28-2003 03:54 PM
Electric tongue jack not extending ipso_facto Jacks, Stabilizers, Lifting and Leveling 5 03-25-2003 11:58 AM
