Old 04-04-2020, 01:15 PM   #1
Houston , Texas
Solved: Voltage Drop on DC Panel
2016 AI GT
Posting should anyone else have these symptoms.
I was experiencing a 1.4V differential between the DC distribution panel and the batteries. Took me several hours to trace down to a corroded bonding cable connection located under the R.S. cup holder.
A tail-tail sign is a big disparity between the Touchsensor reading versus the Magnum. In my case the Magnum was spot on with battery voltage so through exploration learned that the DC panel's Common relies on the AS installed body bonding cable. You can see below the corrosion that was around the connection. Cleaned things up, added a washer for more surface area and things are good as new.
ID:	364825   Click image for larger version
Mcrid is offline   Reply With Quote
Old 04-06-2020, 04:22 PM   #2
orlik's Avatar
2017 Interstate Grand Tour Ext
Gulf Breeze , Florida
Originally Posted by Mcrider View Post
2016 AI GT
Posting should anyone else have these symptoms.......
Very interesting. I plan to check my system as well. Thanks for posting.
orlik is offline   Reply With Quote
Old 04-09-2020, 06:11 AM   #3
2013 Interstate Coach
Raymond , Iowa
Is the amount that they differ load dependent.? If so, how much current was flowing when you noticed the 1.4V difference? Next chance I get I will check voltage as per the Magnum remote versus that on the aux battery switch to see how much they differ.
Titus is offline   Reply With Quote
Old 04-10-2020, 12:54 PM   #4
Houston , Texas
I just had the inverter on, both TVs, and all the LED lights when I took the measurement
Combining 4" drop reciever to Hensley 8" drop shank Rascal0729 Hitches, Couplers & Balls 18 07-20-2015 05:52 AM
Voltage Drop/GFI trip jcanavera Electrical - Systems, Generators, Batteries & Solar 7 06-08-2011 10:09 AM
Acceptable voltage drop on 12V? ESCAPE POD Batteries, Univolts, Converters & Inverters 16 02-24-2011 09:41 AM
voltage drop projector Batteries, Univolts, Converters & Inverters 6 09-16-2010 02:24 PM
voltage drop in storage? boondockdad Batteries, Univolts, Converters & Inverters 28 02-01-2009 12:05 PM
