Old 10-04-2020, 03:19 PM   #1
Emerald Isle , NC - North Carolina
Solar Trickle Charge
I am the 2d owner of 2016 Interstate. Existing AGM house batteries currently has a 2 pole Sae connector wired to the batteries (see red arrows; assume to accept a battery tender). I park my RV under cover so solar panel is ineffective for keeping batteries charged and keeping up with parasitic drain. I would like to use a portable solar panel (Renogy 100W with 20amp controller) to keep the batteries charged. I can place it outside of the covered parking spot I am in to access sun. Any input on this idea would be welcome.
Michael Oehl is offline   Reply With Quote
Old 10-04-2020, 03:28 PM   #2
daleyocum's Avatar
2018 25' Flying Cloud
Portland , Oregon
The first thing to do is install a disconnect of the batteries to the rest of the unit. That way the only parasitic drain is internal to the batteries themselves.
After that, your 100w panel is more than fine. I used to use a 10w solar panel from Battery Tender in my covered storage yard. It got maybe an hour of highly off center sun per day and was fine for keeping the batteries charged.
daleyocum is offline   Reply With Quote
Old 10-05-2020, 07:53 AM   #3
Thanks for your response. Vehicle is an Interstate. Given low level of parasitic draw, is there any real need to install a disconnect? I assumed a 100W portable panel would more than cover the minor draw while concurrently keeping batteries "topped off". Not being too savvy about the intricacies of the Interstate's electrical system I am more curious about the viability of introducing charging current directly to the house batteries via the wiring setup I inherited and depicted in the photo.
Old 10-05-2020, 02:48 PM   #4
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
The parasitic drain on the Interstate is about 0.5A at 12VDC. Your plan to use a 100W solar panel with controller should work just fine to keep you batteries charged when parking your Interstate and not running the coach systems. Just connect the output from the solar controller to the connector in photo you posted.
- - Mike
Old 10-05-2020, 02:56 PM   #5
daleyocum's Avatar
Portland , Oregon
I agree as long as you get enough solar.
A cutoff need not be a complicated thing.Something like this or this would do the trick.
Solar trickle charge bbruntil Generators & Solar Power 2 11-14-2018 11:55 PM
Solar trickle Charge philipsinewe Batteries, Univolts, Converters & Inverters 8 11-03-2016 11:23 AM
Solar trickle charge mike28 Generators & Solar Power 11 04-18-2014 08:56 PM
Will mini solar panel trickle charge over winter? woodytwo Land Yacht/Legacy Motorhomes 14 12-19-2011 05:24 AM
Can I Trickle Charge into the 12V Wall Jack? westeagle Electrical - Systems, Generators, Batteries & Solar 5 01-21-2004 03:19 PM
