Sliding door interference
Over the 14 months that we have owned the AI, an ongoing irritant was the necessity of slamming the sliding door to get it to latch.
I found that the image of the frame and the stretchy cords framing the storage cubby at the bottom of the door was deeply imprinted on the door panel, indicating that the door was rebounding off the frame. I temporarily removed the frame and found that the door closed much easier. I use the cubby for storing my tire gages, so I wanted to keep it.
I removed the cubby box and used my bandsaw to cut off the flange at the top and bottom that is hidden under the frame. I still wanted the stretchy cords, so I used my table saw to cut a shallow trench for the toggles at the ends of the cords. I drilled holes through the remaining plywood for the cord. The toggles lay in the trench so that they don't protrude past the ends of the cubby box and prevent reinsertion.
With the flanges gone, I needed something to support the rear of the cubby box. I used my planer to cut some plywood to the depth of the outer lip so that the box will be supported.
A few screws and the job is finished. Since we have an intermediate stop on the door, the door is seldom opened far enough to see much of the storage cubby. The only things noticeable are the shiny screw heads. Sometime when I have time, I'll put a spot of black enamel on the screw heads to make them pretty much invisible.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
